Sponsored by: Real Truck
Using relays for headlights
Old May 19, 2014 | 01:27 AM
Streaky's Avatar
Streaky
Good morning to all
So my 2005 F350 had those terrible sealed beam head lamps that glowed a very dim yellow...after some advice on here I purchased a set of these lights directly from Ford. Replacement F100133Q-PLK Headlight | Auto Parts Warehouse
Yesterday I fitted them and despite a marked improvement I still can't help thinking that the halogen performance isn't as good as it could be.
Do Ford run their 2005 F350 head lamps Hi & Lo beams through relays? If 'No' then this would be my next step to getting proper illumination at the front of my vehicle.
Comments and advice welcome.
Old May 19, 2014 | 02:11 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I believe they are.
Dont feel bad, Ford truck headlights are notorious for complaints that they arent bright enough. Most generations.
Old May 19, 2014 | 02:23 AM
Streaky's Avatar
Streaky
Wow...that's surprising! Do you guys eat more carrots than us Brits then?
The new H13 bulbs are a marked improvement over the old sealed beams...but they aren't a patch on my 1998 Land Rover than still uses old school 55w H4 bulbs.
If I knew for sure that the Ford uses relays in it's headlight wiring I'd be content...but I sense you're not 100% certain Trey?
Old May 19, 2014 | 03:32 AM
Yahiko's Avatar
Yahiko
Check the voltage at the lamp. I am willing to bet
that it down a bit from the 12V that you should see.
My 1988 Ranger was a dim light and I put a set of
relays in it and a set of Hella H4 lamp kits and talk
about better light. then I went to 80/100 lamps.
Was really nice off-road at night. To be nice they
were pointed really down so that on low beam they
did not fry anyone's eyes. But on HIGH WOW!!
Back to the relays. They will allow you more power
to the lamps with the larger wire. Use a fuse and go
to the battery.
Sean
Old May 19, 2014 | 03:57 AM
Streaky's Avatar
Streaky
Thx Sean. During the light swap I had to change the connector plug from the old style 3 blade type to the newer sealed push-in type connector and couldn't help but notice that the wires used for the these newer lamps are very thin gauge wire.
I wonder if these thinner wires can cope with the extra voltage? I'll get the meter out tonight and see exactly how many volts the lights are getting.
Old May 19, 2014 | 04:11 AM
Yahiko's Avatar
Yahiko
I should of said that.
Smaller wire means that it can't carry
the current as well and tends to heat.
That is why if you look at any truck that been on the road for a
few years the lamp plugs are likely starting to discolor from heat.
This is one of the few places I say aftermarket parts are much better.
You can get a plug with heavy wire/pins and the housing is ceramic not
the plastic that discolors and gets brittle.
Sean
Old May 19, 2014 | 04:16 AM
asdrew's Avatar
asdrew
fwiw I just replaced the bulbs in my 2005 headlamps like you just purchased and they are brighter and whiter now.
The original 9 year old Sylvania H13 bulbs were still burning strong even though they've been on constantly with the DRL module I installed.
I used Wagner BrightLite bulbs #9008BLX2 and a two-pack was only $22 from RockAuto.com
Might be worth trying before you fiddle with wiring & such.
Old May 19, 2014 | 09:36 AM
eberlestock's Avatar
eberlestock
I believe painless wiring sells relay kits just for the purpose of brighter headlights.
Old May 19, 2014 | 08:04 PM
Yahiko's Avatar
Yahiko
Most if not all incandescent lamps dim with age.
Sean
xenfinityx
2004 - 2008 F150
May 23, 2015 08:21 PM
xbox73
Dec 3, 2012 02:52 PM
jroc_kzoo
Mar 30, 2012 07:12 PM
RippedF350
May 7, 2011 04:52 PM
FordCrusherGT
Oct 23, 2008 08:26 PM
