tow package wiring
It does have the tow package.Ihave heard that there are wires for the controller under the dash.I have one plug that makes me think it's the one i need.It's a black round plug with 3 wires.
RED,blue with black ,and red with green.Are these the ones i need?have already ran my wires to the 7pin connector.But trying to see if i have to run a seperate hot wire for the brakes and battery or if I can just splice into the black connector.
thanks for any help.
Since you already have everything wired up but the 12v power for the controller, I would recommend running a new, heavy wire from the battery. That way you can connect a 15 or 20 amp circuit breaker into the line supplying power to the controller.
I would also recommend not grounding the controller underneath the dash, but instead run the ground directly back the negative post on the battery or at least to a good ground on the frame.
Scott
