Gray CPS: Cancelling Power of the Stroke?
Old 05-17-2014, 08:56 AM
Tugly's Avatar
Tugly
Tugly is offline
I have looked at a lot of data with the gray CPS in my truck and in others, and I hate that thing. The idle sucks, the PERDELs are high on 3 and 8, and Stinky just doesn't "sound right" on any tuning I've ever had (including stock), with a stock truck or a modified truck. I was able to get my hands on a black Ford CPS, and that made a big difference in Stinky in every scenario - I experimented back and for the with gray and black many times. I have seen a lot of information on the Riffraff Diesel OEM CPS, and I bought one as a backup... but I have not installed it in Stinky to verify what I'm reading on it.
I now have new intel: A fellow member swapped from the gray to Clay's OEM CPS and his all-around performance shot up, including fuel economy. His RPMs dropped (per MPH) as well. While I'm still sorting out the "why" of all this, it's almost irrelevant: What matters is the improvement with such an inexpensive and easy change of hardware on an aging truck.
I AM NOT SAYING BREAK OUT YOUR CARD AND BUY THIS NOW! I will also not suggest that a new CPS will miraculously take your economy from 14 MPG to 17.5 MPG - there are too many variables on owners and conditions of the different trucks. I am saying all my experience and research says the gray CPS is not ideal, and Ford seems to agree - since they no longer sell the one that was in my truck (installed in 2010 by Ford before I bought it). There is a newer gray one at the dealership with a purple O-ring, but I can't keep up with the variations on these things. I just know Clay has done his homework, and he is providing the best available product he can get on his shelf. One member put that in, and it was a radical improvement over one of the variations of gray CPSs - just like the black one did for Stinky.
If you don't have a backup CPS, I'd order one of these. If you can afford to experiment - this is an inexpensive and easy throw at the dart board.
Numbers: I have 3.73 gearing with stock-sized tires, and I get 2000 RPM at 72 MPH. The member in question went from 2000 RPM at 68 MPH to 2000 RPM at 73 MPH... just by changing from a gray to a "Clay". I suggest you look at your speedo and your tach, but you need to compare it with others of like gearing and tire size. If your RPMs read high for the speed, then you are a candidate for this experiment - or a new torque converter... but that would be a different thread.
This has been a public service announcement of the Stink-N-Rich research and development team.
Old 05-17-2014, 11:45 AM
PaulDH's Avatar
PaulDH
PaulDH is offline
Thanks for keeping us informed. I purchased two extra black CPSs from Clay before the supply disappeared in about 2011. My truck had a black CPS, along with a black spare CPS in the glove box, at the time I purchased it. Ford wanted to change mine out under recall when I had them install the recall wire harness that was involved with cruise control - to reduce a fire risk. I asked them if I got to keep the black one or if they kept it. They told me they kept it. I told them no thanks. They looked at me sorta strange, but I'd never read anything positive about the Gray one they were going to install at the time. And I wasn't about to trade my black for their gray.
Old 05-17-2014, 12:06 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is online now
Received 1,593 Likes on 1,067 Posts
So it changed either the tires or the gearing. That's the ONLY way the RPM/MPH ratio can change. A CPS CANNOT do this!
Old 05-17-2014, 02:57 PM
HKusp's Avatar
HKusp
HKusp is offline
I was wondering the same thing Mark.
Old 05-17-2014, 06:29 PM
ToMang07's Avatar
ToMang07
ToMang07 is offline
Stop trying to make so much sense.
Old 05-17-2014, 06:51 PM
PaulDH's Avatar
PaulDH
PaulDH is offline
Isn't the cam sensor the source of the signal for the tachometer. Which reports RPMs?
I understand that if there is no slippage whatsoever in the drive train between the engine crankshaft and the output drive shaft, that the RPM and speedometer ratio cannot change or drift - such as when in overdrive.
But can the CPS be a source of errant RPM information?
Old 05-17-2014, 09:40 PM
Tugly's Avatar
Tugly
Tugly is offline
I have no clue on this one. I know the #8 "door" for the CPS is the skinniest one, and the #3 comes in second on the anorexic metal pageant. I can only speculate that the CPS wasn't reading 8 correctly, making the CPS miscount... but that's a long throw down the field.
Old 05-18-2014, 09:41 AM
HKusp's Avatar
HKusp
HKusp is offline
Just for reference, I have 3:73's and 35 inch tires. I am running 2000rpm at 72mph with the speedometer re-calibrated using AE.
Old 05-18-2014, 01:43 PM
jr2000sd's Avatar
jr2000sd
jr2000sd is offline
I have 4:10 gears and running 235 85 16 tires and im at 2200 rpm at 70 so im eating fuel on the freeway so i just put a set of 265 75 16 tires on to bring down the rpm's a bit, gotta try a run and see how it goes but i havent seen a difference in changing cps's im running a new black ,purple o-ring international cps and it runs good
Old 05-18-2014, 03:42 PM
Ford79's Avatar
Ford79
Ford79 is offline
You likely won't see any change in RPM by switching tires. 235/85/16 and 265/75/16's are almost identical in overall height. Your downfall is the 4:10 gears.
For the record, I run about 68 mph @ 2000 rpm with 235/85/16 and 285/75/16 tires.
Old 05-18-2014, 11:45 PM
jps47's Avatar
jps47
jps47 is offline
this is the only one I can find, is it the good one?Motorcraft Cam Position Sensor CPS 94.5-03 - Riffraff Diesel Performance
Old 05-19-2014, 07:29 AM
Firefighter 1406's Avatar
Firefighter 1406
Firefighter 1406 is offline
That is the one.
I have talked to rich about this and agree 100% with him thoughts. I swapped mine out with the one listed above and have 285 tires fixed with AE. I also experienced the change from 68 to 73 mph at 2,000 rpms. I don't understand it either.
Old 05-19-2014, 08:01 AM
Pikachu's Avatar
Pikachu
Pikachu is offline
This is one of those things I can't bring myself to believe without seeing it firsthand. Like Mark said, the CPS can't change the drive ratio; it's physically impossible. If the CPS was doing any miscounting of cylinders, it should cause a code to be thrown, or at least a stumble/stall condition.
Old 05-19-2014, 08:12 AM
Tugly's Avatar
Tugly
Tugly is offline
...im running a new black ,purple o-ring international cps and it runs good
Without looking at my CPS in the DuHa, I think these two are the same... and the one at Riffraff is the one I was referring to.
Remember - I'm not stating this is a miracle cure for anything. I'm saying if you have the $25 and ten minutes, it's worth a shot - IF YOU ARE HAVING ISSUES WITH YOUR TRUCK.
Old 05-19-2014, 09:34 AM
clux's Avatar
clux
clux is offline
While it might be possible that it's changing what the gauge is telling you rpm's are, it can't actually be changing rpm's at any given speed, that is impossible.
Since our tach is not mechanical that would lead me to believe our stock tachometer is yet another idiot gauge that is telling you something that may not be completely accurate with either CPS.
Quick Reply: Gray CPS: Cancelling Power of the Stroke?
