Help finding apron grommets
Old May 15, 2014 | 09:59 PM
stevevize's Avatar
stevevize
On my 59 inner fenders (aprons) I would like to replace the rubber grommets. They mount in a 1-1/8" hole in the lower portion where it bolts to the firewall. I found a number 44725-s(x-22) on the image but could not find the part number. Any help would be nice. Numbers Dummy, are you out there? Thanks in advance.
Old May 15, 2014 | 11:11 PM
Danleig's Avatar
Danleig
I started a thread about these awhile back but it didn't go anywhere;
https://www.ford-trucks.com/forums/1...-bushings.html
I ended up finding some that are close, get yourself Mil Spec grommets MS35489-102.
When you remove the old ones keep the steel inner sleeves and the bolt/toothed washer combo to use on your new grommets.
Old May 16, 2014 | 02:09 PM
stevevize's Avatar
stevevize
Talking apron grommets
Thanks Danleig. Tire Carcass? That was funny.
Old May 29, 2014 | 01:20 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by stevevize
On my 59 inner fenders (aprons) I would like to replace the rubber grommets. They mount in a 1-1/8" hole in the lower portion where it bolts to the firewall. I found a number 44725-S8 on the image but could not find the part number.
The standard aka hardware part number you came up with is listed as a flat washer, not a grommet. Standard parts in pics may not have the complete suffix.
44725-S8 .. Flat Washer- 5/16" x 1 1/8" / Listed in text section on page 1762 following the 16005-6 front fenders.
(X22) This is the location in the standard parts...parts bin for 44725-S8
mrpotatohead
Jun 15, 2019 06:08 AM
wharthog
Jan 22, 2019 03:18 PM
GJCAT
Large Truck
17
Feb 21, 2018 12:53 PM
4x4slik
Aug 8, 2016 04:59 PM
F250GH
Oct 17, 2008 06:51 PM
