Here is another hard one. I need a spring clip for a bolt on the hand brake drum assembly. It holds the headless bolt 7EQ2616 and stops it from turning. Green Sales has the bolt which I already have but I can not find a part number for the clip and Green Sales said it does not come with the headless bolt. It screws into a TGAA2621A I am working on a C-800 hand brake 10 1/2 in drum. Any help would be great. Thanks
OK, I looked up your part numbers in the Parts Catalog. Looks like the headless bolt has a hole in it for safety wire, just like all the headed bolts on the other models. I don't know what clip you're looking for. It's not shown in the diagram, but neither is the safety wire in this drawing.
Here's a drawing of the another headless bolt with safety wire for your reference.
Big Job, the part numbers he gave are shown below .
7EQ 2616
48/ Parking Brake Band Anchor Clip Adjusting Bolt - THQ, Q, QH, #QH, QHS, QW, QHW, QSW, Z, ZW 5/16"-18 x 1 3/4" headless
TGAA 2621-A
53/56 Parking Brake Anchor Bar - QH, QHW (except T/A) (MS, QSW Q with tandem axle with tandem axle & auxiliary transmission with tandem axle 9 27/64" long
On a side note, I converted both my Text and Illustrations Catalogs to searchable PDFs. Makes looking for numbers much faster.
It has an external drum. The bolt is headless and has a slot cut into the top. The spring clip fits in the slot and then pushes though the other small hoes in the bar to keep it from turning.
I am sorry, the bolt passes through the bracket on the brake shoe and screws into the bar. The small holes that the clip fits into are in the bracket on the brake shoe. There are three hole in the bracket for the brake shoe, center hole for the bolt to pass and two smaller holes for the ends of the clip to fit into.
Have you ever seen this clip you're referring to? It's not in the parts manuals. The diagrams I posted show where the safety wire runs through the hole in the bolt to the holes in the bracket to keep the bolt from turning.
Looks something like this, except I have the spring on the outside instead of the inside of the bracket.
That is the idea only no head no whole and just a deep slot. I will try to post a picture.
OK. Safety wire through a deep slot would accomplish the same end. It's just there to keep the bolt from turning once you have the adjustment gap set. The slot is probably for turning it with a screwdriver?
