zf5 brake
Old May 15, 2014 | 09:27 AM
Fireman_dave's Avatar
Fireman_dave
zf5 brake
Well after converting my truck from auto to stick i decided for parking breaks to get the zf5 brake assembly, i bought one but there aint no way it is bolting up....anyone got an idea?
Old May 15, 2014 | 10:53 AM
Ford F834's Avatar
Ford F834
It bolts to a 4x4 ZF-5 in place of the transfer case... Is your ZF 2wd or 4x4? If it's a 2wd transmission it won't work.
Old May 15, 2014 | 02:38 PM
tjc transport's Avatar
tjc transport
i ain't rite
as said, to use a drive line brake assembly, you need a 4X4 transmission. it bolts to the tail shaft of the trans where the transfer case adapter bolts.
it will not work on a 2 wheel drive trans.
Old May 15, 2014 | 05:29 PM
Fireman_dave
Its a 2 wd i guess i need to resell it. :-(
Old May 15, 2014 | 05:43 PM
bashby's Avatar
bashby
So why do you need to add a parking brake? If you let us know what you're trying to do you might get some helpfull suggestions.
Old May 15, 2014 | 08:58 PM
wtroger's Avatar
wtroger
If it is 2wd then it should already have parking brakes.
ReBilld
Jan 31, 2013 09:19 PM
scl009
16
Aug 9, 2012 07:40 PM
fordguy76
May 19, 2011 10:52 PM
Steve's Beast
Jul 23, 2004 02:04 PM
