Will the zf work?
Old Jul 21, 2004 | 08:14 PM
Steve's Beast's Avatar
Steve's Beast
Talking Will the zf work?
Well I think I found a good zf for my truck. It looks like it should work fine.
It is in a 88 F??? (Duelly) 2WD with 460Efi
SN# 2FDLF47G1JCB03617
Stuff on door: WB: 161 TYPE GVW: F476 BODY: LB8 TRANZ: Z AXLE: 72
Trans S# 8032319
Ford Part # E8Ta-7003-aka
Build date 03/04/88.
It has what I think is the parking brake bolted on the end of the tranny Not shure though, the bugs where chewing me so I hade to be quick!
Can anybody tell me if I can use this zf behind my 460 in a 81 F250 4WD BW-1345 Tcase.
Thanks
Steve
PS. Can anybody tell me What ford? (F450, F550...????
Old Jul 21, 2004 | 08:57 PM
FordPerf300's Avatar
FordPerf300
if it's 2x you'll need to get the 4x4 output housing and output shaft, i'd keep looking unless you wouldn't mind running a divorced tcase
Old Jul 21, 2004 | 11:26 PM
Steve's Beast
It looks to me that this park brake assy will unbolt and my t-case will bolt up in its place. I don't know if the shaft is the same that is why I posted.
I will try to get a pic of the unit after work tomorrow.
I have the part# for this,
ZF Parts List# 6051 001 002
Brake 9X3 IN
Trans #8011998
There was more but the mosquitoes where horrid!
Steve
Old Jul 22, 2004 | 02:05 AM
82F100SWB's Avatar
82F100SWB
Sounds like you found youself a F450 or FSuperduty with a driveline brake.
The brake will unbolt and your transfer case will bolt right up in it's place.
Old Jul 22, 2004 | 06:29 AM
RTM's Avatar
RTM
I agree with the others, any ZF with the rear drum brake assy. is the same trans found in a 4X4.
Old Jul 23, 2004 | 12:18 AM
Steve's Beast
So my borg warner 1345 will bolt up?
Thanks for the replys!
Steve
Old Jul 23, 2004 | 06:59 AM
RTM's Avatar
RTM
Yes it will.
Old Jul 23, 2004 | 02:04 PM
Steve's Beast
Thanks everybody! I was hoping it would work.
Steve
Squirrel Man
16
Dec 6, 2016 10:57 AM
Poorboy1967
Sep 7, 2016 04:53 PM
apachetech
Oct 3, 2015 10:52 AM
brock smith
Sep 20, 2015 04:55 PM
crazed87bronco
Feb 10, 2011 09:15 AM
