Amazing that someone would go to the trouble of cutting through the fender, then do such an obvious redneck hackjob of the exhaust. You know that thing's going to get screwed up in a parking lot sooner or later.
I don't care for the way it goes through the fender, but what I would like to see, is a stack kit that goes on the outside of the box from underneath, instead of through the box.
I'm actually planning on putting a stack on my Courier, but a little different. I want to notch the front corner of the bed and run the stack up there, but I also want to put a military style canvas top on it so it may just get the stack up the outside. It'll have a snorkel too so it will actually be for a reason other than looks.
Although, this Dodge does have a stack and a cap-
I actually like the idea, as I like caps and my main objection to stacks is that you have to cut a hole in the bed to install one. But I wonder, wouldn't the stack and/or cap get damaged over time, with all the rubbing between the box/stack/cap? Seems like every time you get off-camber things are going to flex and rub.
