Short throw shifter.
Old May 14, 2014 | 10:58 AM
Jarryd's Avatar
Jarryd
I know the Hurst part was discontinued for the m5od, but I found this on eBay today. A little pricy, but what do yall think? Only reason I was looking is my stock shifter is sloppy as can be and moves around a ton in gear.
http://pages.ebay.com/motors/link/?nav=item.view&id=281328956387&alt=web
Old May 14, 2014 | 11:04 AM
Jarryd's Avatar
Jarryd
I wasn't really looking for a short throw being that it's a truck and gets used as one, was just looking for a fix for my sloppy shifter.
Old May 14, 2014 | 11:34 AM
dixie460's Avatar
dixie460
Why not just replace the bushings in your stock shifter then?
Old May 14, 2014 | 11:46 AM
Jarryd's Avatar
Jarryd
Stumbled across this when I was looking for them, I know I had seen people talking about it in the past. Thought I'd share.
Old May 22, 2014 | 06:33 PM
SideWinder4.9l's Avatar
SideWinder4.9l
Well, I'll add my $0.02 USD..
I paid another member $150 for the one he found me one in a JY. that included shipping; Looking back, was it necessary? Absolutely not.
Was it worth it? IMPO, YES. My ENTIRE range of 1-2 shift is now literally what 1-N used to be. And it re-aligns itself over 3-4. instead of 1-2 like a stock one does.
And the fact I take a trip or 2 a year to Clay City to play around, makes it even better.
Not to mention it no longer bashes the 44oz speedway drinks out of my cupholder...lol
Old May 22, 2014 | 07:57 PM
Jarryd's Avatar
Jarryd
Random bump but solid info. I need to decide if I'm going to go to a zf5 down the road.
Old May 22, 2014 | 10:01 PM
SideWinder4.9l
I know..lol
That is the ONLY reason I've not really felt the need to swap to a ZF, and that's the simple fact that I can't re-use my Hurst shifter.
Old May 22, 2014 | 10:03 PM
Jarryd's Avatar
Jarryd
I know..lol
I'm going to need a new tranny when I do a 4x4 conversion and I'm going to use what I can get but I'm also wanting to build an engine way down the road and I need something that can back up a built engine.
Old May 22, 2014 | 10:10 PM
SideWinder4.9l
Just a random thing to add...
The factory clutch disc for the 4.9l version of the M5OD-R2 is a 10" setup.
The Factory setup for a 5.0l M5OD-R2 is 11".
If you have the flywheel resurfaced, you can swap to a 5.0l clutch disc (Both has the same mounting bolt pattern, etc...It's just the pad portion is 1" wider) and you'll gain "Holding power"..
I should've did it when I redid my tranmsission 4 years ago; But alas, I did not.
But I do know that if I feel the need to swap discs, I'll be doing the 11" "Upgrade".
Do not ask me why there's a difference, because I have 0 idea.
Old May 22, 2014 | 10:12 PM
Jarryd's Avatar
Jarryd
I actually researched this a while back. Gives you the option of using a heavy clutch too if I'm not mistaken. I got used to the spec stage 3 in my mustang that gave me a workout when I drove it.
My clutch only has about 10k on it.
Old May 22, 2014 | 10:18 PM
SideWinder4.9l
Mine has approx. 40,ooo or so...It's been in there 4 years now.
I would love to do an upgrade when the clutch pad starts wearing out, and get more holding power and more grip.
Old May 22, 2014 | 10:20 PM
Jarryd's Avatar
Jarryd
Grip is good. I'd like to have a 500 ft lb 351w with a spec stage 2 behind it and a nice limited slip front and rear and some good tires. There would be few places I couldn't go.
Motorhead351
WTB - Parts & other
Aug 22, 2015 07:02 AM
RollinHi95
Nov 18, 2006 07:03 PM
mdjohnson
Jan 15, 2006 12:22 PM
FlaresideGlenn
Sep 2, 2003 10:05 PM
