Simple engine modifications
Old May 14, 2014 | 08:19 PM
InvincxbleDan's Avatar
InvincxbleDan
Okay, I understand now.. Thanks for your input!
I'm going to put all of this into consideration when I build it up. Just going to be little mods for now..
Old May 14, 2014 | 09:52 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Straight up timing will wake it up to and since you are in there install a aluminium intake.
Old May 14, 2014 | 10:00 PM
InvincxbleDan
What exactly do you mean by straight up timing?
Old May 14, 2014 | 10:11 PM
77&79F250's Avatar
77&79F250
Instead of the timing be "retarded" for SMOG reasons by Ford way back when, by something like 8 degrees? I might not be exact on the terms or explaniation of this exactily but....
You can get a new timing set gear and chain (double roller?) and get the timing set back to "straight up" or no retardation. I hear that will wake up that 351M alot.
I think you need a timing set for a 72 or 73 400? A advanced thread search will get you some info on it, I do not know the exact part #, I myself have NOT done this mod.
I am sure the 351M links in the other threads above have the part #'s you need.
Old May 14, 2014 | 10:16 PM
InvincxbleDan
Well, cool. Thanks! Your explanation is better than whatever I can come up with haha
Old May 14, 2014 | 11:18 PM
Westcoast Highboy's Avatar
Westcoast Highboy
There is only so much you can do with the 351M platform. They were never great performers even when brand new.
In all seriousness, as all ready mentioned, you may want to consider building up a 460 or 429 as it will bolt right up to your transmission.
Same horrible gas mileage but twice the power and torque. Also lots more aftermarket support and cheaper (relatively speaking) in the long run....
You can buy a junkyard 429 or 460 and build it at your leisure and just keep running your 351M for now. Once the new motor is built, drop it in and hang on!
Old May 14, 2014 | 11:24 PM
InvincxbleDan
Why must the 351M be such a poor performer
Old May 14, 2014 | 11:49 PM
77&79F250's Avatar
77&79F250
Its NOT, well maybe a little, but over all it workable, is just has a bad reputation, ck out those links....
Change the crank to make it a 400 and be happy.
History of the Ford 351M
M-Block 351M/400 Parts Reference
351M/400 Performance Build Up
Rumors & Myths
Prove them naysayers wrong!
Old May 14, 2014 | 11:56 PM
InvincxbleDan
Haha I'll be happy with any kind of power gain.
Old May 14, 2014 | 11:58 PM
85e150's Avatar
85e150
Rumors & Myths
See post number 4.
Old May 15, 2014 | 07:37 AM
77&79F250's Avatar
77&79F250
Yes I seen it, I figured the OP didn't. Not meaning to steal your "link thunder", just double tapping a target.
Old May 16, 2014 | 12:10 AM
85e150's Avatar
85e150
I think you figured right.....
Joel Cassell
Apr 8, 2016 02:32 PM
HVACTOM
33
May 11, 2015 06:50 AM
roger dowty
Jul 13, 2005 03:25 PM
satx77stepside
Nov 10, 2003 07:25 PM
dsc
Mar 27, 2002 04:41 PM
