96 ford f-150 starting problems
Old May 14, 2002 | 03:54 PM
jwilliams777's Avatar
jwilliams777
Post 96 ford f-150 starting problems
My 96 F-150 has problems starting. This is totally random. Cold/Hot doesn't matter. 25 % of the time it starts normally, 25 % of the time it will not start with out flooring the pedal ( but doing this makes it run rough and it will not idle ) and the other 50 % it will start with a little help with me slightly pumping the pedal as I turn over the engine.
So far I've replaced of checked
1) Fuel filter replaced
2) timing is ok
3) plugs replaced
4) cap and rotor replaced
The funny thing is, if I have to start it by flooring the pedal it will run rough and will not idle, but give it time and it will kick in like normal giving me a smooth ride and idle.
Could some one please give some advise.
Thanks
John
Old May 14, 2002 | 04:59 PM
mantta's Avatar
mantta
I would start by disassembling and cleaning out the isle air control valve. Have you checked the computer codes?
Old May 14, 2002 | 05:25 PM
jwilliams777
Ok, thanks. I will check that this weekend.
I haven't checked computer codes yet either. So, I guess I will do that also.
Old May 14, 2002 | 06:13 PM
Bronco2Mudder's Avatar
Bronco2Mudder
schlik83
Aug 8, 2020 08:21 AM
Colton Haight
Oct 2, 2016 12:18 PM
patrick.sellers
2004 - 2008 F150
Oct 30, 2011 11:50 AM
1994_F150_302M
83
Jan 19, 2006 10:43 AM
celticrebel
1978 - 1996 Big Bronco
Mar 18, 2004 10:49 AM
