ignition issues
Old May 13, 2014 | 10:01 PM
Crewcabber's Avatar
Crewcabber
That makes perfect sense. If there that new I wouldn't replace them either.
Old May 14, 2014 | 08:34 AM
coffmajt's Avatar
coffmajt
Originally Posted by scubasteveF250
does the pip throw the check engine light on also, im going to borrow a code reader for the obd 1 system tomorrow just to make sure before i start throwing new parts into it again
The PIP itself shouldn't throw a code because it usually just fails and stops sending the signal to the coil. It is possible for it to die a slow painful death and trigger random ignition misfire which will throw code 0300.
Old May 14, 2014 | 08:24 PM
scubasteveF250's Avatar
scubasteveF250
yea it just died, got one ordered, will be here tomorrow, only code i had was 34, which is egr, but everything is pointing to the pip sensor so im going to change it and hopefully that fixes the problem
Old May 14, 2014 | 08:59 PM
Crewcabber's Avatar
Crewcabber
Keep us posted Steve
Old May 14, 2014 | 09:10 PM
scubasteveF250
once i get the new pip sensor in and get it running again ill post an update
Old May 24, 2014 | 04:07 PM
scubasteveF250
pip sensor was junk, changed it last friday and its been running great since then
Old May 24, 2014 | 07:15 PM
rla2005's Avatar
rla2005
Great to see you got it going. Those pesky PIP sensors can be real devils at times.
jgreen82
Dec 8, 2013 04:31 PM
ENCLOSURES
33
May 12, 2011 05:42 PM
mox-ct
37
Aug 17, 2010 04:15 PM
jab55
Mar 6, 2008 01:23 AM
428_cobra_man
Aerostar
Oct 24, 2004 03:33 PM
