88 ranger starting problems
Old Jul 6, 2003 | 04:23 PM
ford94150's Avatar
ford94150
My sons ranger has the following symptoms: I get a clicking sound when trying to start, it will start with a jump but when the ranger is turned off it just clicks....what could this be? I would think if it were the starter or starter solinoid then even with a jump it wouldn't start...I put a new battery in yesterday?
could it be the alternater?
thanks
Old Jul 6, 2003 | 04:28 PM
tworangerted's Avatar
tworangerted
are you sure the new battery is good??Sounds bad to me if it starts with a jump.
Old Jul 6, 2003 | 05:15 PM
Bob Ayers's Avatar
Bob Ayers
If the new battery is ok, then I would check the battery cables
very carefully!!!!!
Old Jul 6, 2003 | 05:57 PM
mrwizard's Avatar
mrwizard
Get a volt meter and check the battery voltage. Should be about 12.5 or so with the truck off, and around 13.5 or 14 when running. If it's lower than that when it's running, you've probably got a bad alternator. Most parts shops will check them for free.
Old Jul 6, 2003 | 07:13 PM
ford94150's Avatar
ford94150
when the truck was running I measures 12.5 volts
triplehellcat
1997 - 2003 F150
Jan 4, 2014 06:13 AM
Harley Fee
May 6, 2012 05:31 PM
cdnmshoem2002
Mar 9, 2010 06:48 PM
spyder31157
Nov 10, 2008 10:23 PM
MineralStang
Jun 10, 2006 05:57 PM
