Servicing rear wheel bearings in 10.25" full-floater
I did find some interesting things with my rear brakes. The lining on the rear shoe on the passenger side was broken into about 4 separate pieces. Most of them were still riveted to the shoe, but one piece about an inch square was sitting in the bottom of the drum. And at least on the driver's side the parking brake lever was a pretty solid press-fit onto its pivot bushing (now I know why my e.brake wasn't working). There was still a lot of thickness left in the linings before the rivets would hit, and the drums both looked really good, no scoring, no ridge. But the brakes were certainly due for service!
...not for a full-floating rear end. their cheap one is 34.00 ... motorcraft is 66.00.
when my seal started leaking i only discovered it during a routine brake check. it was just starting at that point.
6 months later when i finally got around to doing it, there was lube all over the place but none ever showed out the backside of the drum.
gamehunter
11-29-2002 04:09 PM
