rearend
Old May 10, 2014 | 11:21 PM
pineflatg1's Avatar
pineflatg1
rearend
where can i find a rear end for my 62 uni ,292 4 speed or can someone tell me what rear end i have and what might interchange
Old May 10, 2014 | 11:38 PM
85e150's Avatar
85e150
Do it look like so?
http://www.cometeastcarclub.org/images/75753-500-0.jpg
Or:
http://upload.wikimedia.org/wikipedi...JeepDana44.jpg
What do you need? Housing? Gears and bearings? All? Part?
Old May 10, 2014 | 11:47 PM
pineflatg1's Avatar
pineflatg1
Im looking for the whole thing and it looked liked the picture in the first link bolts same side as driveline i was hauling a trailer when the axle broke then the the tire went out the back broke front bolts in bumper and truck went quite aways draging on the vaccum plate or pressure plat whatever that thing is called you attach the brakes to it grinded about 3 inches off of it
Old May 10, 2014 | 11:52 PM
pineflatg1's Avatar
pineflatg1
i was looking at one on a 57 somebody had made it into a trailer it looks the same as mine except mine has shock braket in front and the 57 has them in the back i was just going to weld them were i wanted them i just dont know if they would interchange.
Old May 10, 2014 | 11:55 PM
85e150's Avatar
85e150
Welcome to FTE by the way.
That there would be the Ford 9 inch rear axle. Famous, known as "..the poor man's quick change", as that drop out carrier makes gear changes a snap. Used in NASCAR, even in the Toyota car. Used in drag racing, all kinds of racing.
Used in all kinds of pickups too. Produced '57 to mid '80s.
AFAIK the Uni is the same width chassis as others of the same era, so I would think any F100 '61 to '66 is a possible donor for all parts.
Others here may be able to steer you to other years that share the same width and spring pads etc.
The brake backing plate is what you are talking about.
So you need it drum to drum and probably a few other parts as well.
You may have troubles finding a true drum to drum bolt in, but as long as you find a housing, you can switch your thrid member over, and your axles and the one good brake if all those parts are sound.
Old May 10, 2014 | 11:56 PM
85e150's Avatar
85e150
You can do that. Check overall width and spring pad width.
Check that housing for "true" also. You dasn't want a bent one.
Old May 11, 2014 | 12:25 AM
pineflatg1's Avatar
pineflatg1
thank you kind sir for your help it is appriciated i might just go to the junkyard and see if i can find a drop out that will fit but i hope i dont ever have this problem again.
Old May 11, 2014 | 08:14 AM
scottlathrop's Avatar
scottlathrop
I know this is a little late, but is the metal tag still under one of the bolts? There are people here that will decipher the code on it. Worth a look. The warranty plate on the drivers door gives much of that info if it the original. Good luck
Old May 11, 2014 | 08:50 AM
Shadowrider123's Avatar
Shadowrider123
F100 up to 72 will fit just fine. Make sure it is a 2wd, the 4wd has different brake cylinders.
There are lots of them in salvage yards around here, not hard to find at all.
Old May 11, 2014 | 08:51 AM
tinman52's Avatar
tinman52
Welder User
57-72 F100 9 inch rear ends are basically all the same and will bolt in. '68-'72 have slightly bigger brakes.
'73 up are wider.
Old May 11, 2014 | 11:35 AM
pineflatg1's Avatar
pineflatg1
thank you
Well with this insight i think ill go ahead and buy the one of f the 57 I've measured drum to drum and spring to spring and I'm on my way to pick up the 57 i just hope they have all the parts at the parts store i want to get. On a side note this is my only truck i use it for work and play and everything else i rea_lly like this truck. I was at the gad station a while back and an older gentlemen came up and offered me 5 grand i told him sorry its not for sale i had anpther guy ogfetef me 9000 I'm curios what makes these trucks so valuble.l
Last edited by pineflatg1; May 11, 2014 at 11:48 AM. Reason: because I'm on my mobile and i can't get the curser to go where i need it to I'm new so i don't kkk.ow if you can delete the whole post or not it acceentally posted in the first place
Old May 11, 2014 | 06:04 PM
pineflatg1's Avatar
pineflatg1
ive got the 57 axle just having trouble removing the axle i took all the nuts off the front does anyone know how to remove the third member
Old May 11, 2014 | 09:39 PM
tinman52's Avatar
tinman52
Welder User
Once you remove the axles it should come out.....might be stuck to the gasket. try tapping around the edges with a dead blow hammer or similar. Don't use a hard faced hammer, you can crack the casting.
Old May 11, 2014 | 09:47 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Old May 12, 2014 | 10:09 PM
pineflatg1's Avatar
pineflatg1
cool
Thanks for everybodys help the 57 rear end fit perfect i had to go get new brake parts but im on the road again think ill be driving pretty slow for a while the steering in the front seems a little harder to turn now. again thanks
Bastin
May 14, 2018 11:32 AM
knash0727
Dec 14, 2007 09:32 PM
Fordys54F100
Jan 27, 2006 12:23 PM
fordiesel69
Oct 18, 2003 02:41 PM
BubbasRacing
Sep 3, 2002 06:22 PM
