New Purchase
Old May 10, 2014 | 09:06 PM
BenOtis's Avatar
BenOtis
New Purchase
Hi guys, I am new to this site so, hello!
I am in the market for a 2006 F250 super duty with the 6.0 Diesel in it.
It has 76,000 miles and has only had one owner. Price: $15,500
It is in great shape and is totally stock.
Is there anything I should be worried about?
Thanks,
Ben
Old May 10, 2014 | 11:30 PM
04badford's Avatar
04badford
Seeing the trucks monitoring Values like engine oil temp vs coolant temp engine hot open road 65 mph flat ground and even hills look at the spread between them no more than 15 deg and that is pushing it, cold starts? and hot Starts be the first to fire the engine first thing cold morning and how long does it take to start engine hot? monitor FICM, Battery, IPR, ICP VGT , when replacing the battery's always replace in Pairs, make sure the alternator is charging good , a bad alt and bat will kill a FICM in a hurry a bad ficm will massacre the Injectors It's Important to monitor these with a Gauge and not the Dash Gauge , Scan Gauge, Dash boss, ETC, the Blue spring will help in Fuel pressure and low pressure is known to hit the Injects aswell we have no sensor for fuel pressure so a gauge would be good to have or at least check and see what PSI it is, one last thing I know there's a lot more but always use OEM , the oil cap and filter is VERY Important and I always stay with OEM fuel and AIR filters too ,NOOO after market set up
Old May 11, 2014 | 12:08 PM
BenOtis's Avatar
BenOtis
Thank you for your reply!
I was able to drive it multiple times for awhile and able to start and stop it probably 6 times. It always fired right up really well.
Does it sound like a good deal?
Old May 11, 2014 | 12:36 PM
04badford's Avatar
04badford
Lower the price and I would jump, as long as the Values of monitoring look good , Did you put some Gauges on it?
Old May 11, 2014 | 12:37 PM
04badford's Avatar
04badford
If you are in Nor California I could hook my Gauges
Old May 11, 2014 | 12:48 PM
BenOtis's Avatar
BenOtis
I don't have any gauges. I'll be meeting them at the dealer to get it. Any other way of checking?
Old May 11, 2014 | 12:54 PM
CPB1's Avatar
CPB1
You need gauges that will read from the OBD2 port.
I use the ScanGauge2, keep in mind you will need to input the X-gauge codes to retrieve the data you want.
Good Luck
Old May 11, 2014 | 01:03 PM
BenOtis's Avatar
BenOtis
I don't have gauges.. I have seen the one you spoke of for like $150 but I don't want to buy it before I get the truck. Would the dealer have these gauges?
The truck runs and starts very well
Old May 11, 2014 | 01:08 PM
04badford's Avatar
04badford
Do you know anybody with such Gauges? Maybe a FTE member will step up and help a Bro out, take a look in the Chapters section for your area, I'm sure there's guys that will help You Need to Purchase some It's very Important to Monitor things before they go south. and helping you with a structured price on the sale
Old May 11, 2014 | 01:11 PM
04badford's Avatar
04badford
I phone Torx app, Dash boss, Scan Gauge, the dealer wont help they want the sale
Old May 11, 2014 | 01:31 PM
BenOtis's Avatar
BenOtis
I don't know anyone with any unfortunately but I will check on here.
Also, I couldn't find any iPhone apps for gauges like you mentioned..
Old May 11, 2014 | 02:35 PM
Mr.Nobody's Avatar
Mr.Nobody
The scanguageII will be the best $150 you spend during to hunt for your new 6.0. Do not wait until after the purchase. I'm sure it looks good and starts great, but that doesn't mean the oil cooler isn't plugged and the FICM isn't at 36 volts.
PLEASE do yourself a favor and spend the little bit of money up front to save the thousands in the end. You will be very upset if you pay top dollar for a truck that needs a couple hundred to a couple of thousand dollars of maintenance. The dealer you are buying from probably has no idea what the ECT/EOT DELTA is, because it's doubtful they checked. That will be up to you. Then if you find issues, you can leverage that into your purchase price.
Old May 11, 2014 | 02:39 PM
BenOtis's Avatar
BenOtis
I will go buy a scanguage 2 tonight so I can have it before I buy it. Now with that said....
Is someone willing to spoon feed me on what I need to look for and so on...
Thanks to everyone for helping the new guy out on here.
Old May 11, 2014 | 02:48 PM
2006White60's Avatar
2006White60
Talking
According to his profile he is in Iowa, is anyone near?
Old May 11, 2014 | 03:52 PM
Iaff113's Avatar
Iaff113
https://www.ford-trucks.com/forums/9...used-6-0l.html
Lots of good reading in all these write ups
