Oil & Lubrication
Oronite Viscosity Index Shearing Mini Tutorial
Old May 10, 2014 | 02:52 PM
pawpaw's Avatar
pawpaw
An easy read mini tutorial on oil viscosity index shearing by Chevron Oronite. https://www.oronite.com/paratone/shearloss.aspx
Viscosity Index Improvers (VII) are used in formulating our multi-viscosity engine oils. The type choice of VII's is important in making a recipe's VI stable, so it won't change much from heat, pounding, squeeze, shear & fuel dilution, during an OCI.
Heavy molecular weight/large size molecule VII's are more prone to Permanent shear/tear viscosity loss, than lighter weight/smaller size molecule VII's.
So the formulators choice of VII's for our particular engine oil recipe & our particular engine design, will impact how much viscosity drop/thinning is due to mechanical molecular streaching/temporary viscosity loss, or molecular tearing/permanent viscosity loss.
Squeeze, shear & heat figure in on how easily or how bad the shear is & if its just temporary, from the VII molecule being streached, or permanent, from the molecule being torn, in which case the oils viscosity will drop/get thinner & stay thinner.
Used Oil Analisis (UOA) with fuel dilution testing, will tell us what the used oil viscosity is & if it has dropped, is it due to fuel dilution/thinning, or mechanical shear/tearing of the VII molecule & that way we can determine if our oil choice is up to the task of properly lubing our particular engine design, the way we're using it during that OCI.
Click on the left side bar titles to read through all of the info.
brown 4x4
Oil & Lubrication
Oct 29, 2022 08:30 PM
Mmaxed
Modular V10 (6.8l)
Oct 11, 2009 09:14 PM
Visseroth
76
Aug 22, 2009 04:42 PM
OrangeJuice
Oil & Lubrication
Aug 28, 2008 05:31 PM
rockcrawlerdude
Dec 26, 2007 04:22 PM
