I did take a 15 for a test drive last night and the truck ran great. NO SURGING!
I am going to try to take a 14 for a ride today.
I think the surging on the 11-14 is the dual compressor side if the turbo. I think the ECM gets confused between the VGT on the exhaust side and then the intake side opening/ diverting air around, then the surge starts. Just my thinking on that.
4800 miles on my 15 and not one bit if surge, which is good.
Interesting... Can you PM me any info I could give my dealer on your truck/case? I talked to a local diesel performance shop and thats kind of the path he suggested. As simple as it sounds he said to change the air filters. So I am getting one today.
I think I still have the shop ticket in my truck. I try to find it this afternoon.
That's part of the issue. I had the vgt replaced on my old turbo with out success. Its a combination of the vgt and turbo from what I found out.
To be clear, this issue is not easily resolved by just pulling into a dealership.
There usually aren't any codes with this issue. A tech has to test drive the truck and replicate the issue, which is not easy. If they get it to replicate, they they should be looking at the vgt signal for oscillation as a starting point.
It's just over compensating to try to hold a power level. Like a bad governor....
Needs power, spools up, gets going a hair too fast, spools down, slows down a tick too slow, bounces back up. Mine has always done this while in regen for some reason, only with an unloaded truck.
It just can't find a neutral power level at that speed without any external load like a trailer.
Makes sense that the fix would be an adjustment to whatever governs the turbo boost, or, by adding resistance to the system so it has something to drag on and stabilize.
Mine only does this under a regeneration as well but not all of the time which makes it interesting as to why this happens.
The conditions are usually under 60 MPH and with cruise control in command.
I can watch the boost gauge move and the CTS reports it.
It's more noticeable some days than others. Sometimes I see it happening but I don't feel anything.
That was one of the very first things my truck was flashed for when initially it was brought in. However it wasn't doing it during regen.
My truck was in and out of the shop since march of this year.
Exactly how mine acted. It would hunt for the right boost at 55 mph to 70mph on flat ground. Throw in hills or other loads and it wouldn't do it anymore. Get on other side of hill and it would start right up again.
I ended up getting my Nox sensor reprogrammed after a power down, and it helped a little. Hopefully they will come out with a "fix" for this. LOL. Thanks for all the good info.
I know. Would be nice! My truck has been in and out of the dealership since May of this year. The Engineers at Ford are now telling my service manager that they are to do no additional work. Hows that for treating a loyal customer?
