Light Switch
Old May 8, 2014 | 04:17 PM
FoundOnRoadDominatin's Avatar
Light Switch
Greetings my fellow enthusiasts!
It's been awhile but now i'm back to the project again, and back where i left off. The light switch issue. I had the 3 of the 4 parking lights on that wouldn't turn off. So i dissassembled everything to get a clear picture of the switch and wiring and sure enough what appeared to be a beige colored wire was striped and burned.
So can I just replace the whole wire? how can i get this fixed?
Old May 8, 2014 | 05:09 PM
Franklin2's Avatar
Franklin2
They sell new plugs with pigtails at the parts stores for just this reason. It happens all the time.
Old May 8, 2014 | 06:56 PM
Gary Lewis's Avatar
Gary Lewis
But, you should also fix the reason it melted in the first place - too much current. The wires and switches Ford used are marginal at best for the amperage the headlights pull. The fix is to install a relay system like NPD, LMC, and others sell. Then the headlight switch will be supplying only enough current to pull the relays in. Problem solved and you will notice much brighter headlights as well.
Old May 8, 2014 | 07:46 PM
Franklin2's Avatar
Franklin2
The wire that burnt is the tan/white wire. It feeds the running/marker lights. I do not know of any kit you can buy for this circuit, but you could certainly add your own relay if you wanted. Ford added a relay to this circuit on dually pickups from the factory.
The headlight section can be a problem also, and the relay kits do help with that circuit. But it's two different things happening here at once.
Old May 8, 2014 | 08:00 PM
Gary Lewis's Avatar
Gary Lewis
Well, that shows what little I know. Jumping to conclusions w/o thinking about it. Sorry.
So, is it common for that wire to burn/melt?
Old May 9, 2014 | 11:59 AM
Any suggestions how to tackle this? I'm a weekend warrior when it comes to mechanic work but I don't know a cent of electrical
Old May 9, 2014 | 12:22 PM
Gary Lewis's Avatar
Gary Lewis
What do you mean by "tackle this"? To fix your problem you don't need a relay. Just go back to Dave's post about getting the connector at the parts store.
I confused things with my post about relays, and it had nothing to do with your problem. Sorry.
Old May 9, 2014 | 01:49 PM
oh ok i got confused there about the relays
afmedic
Dec 9, 2015 03:14 PM
Festus Hagen
Aug 2, 2010 12:56 AM
Bernie Lomax
Mar 27, 2008 12:52 PM
imlowr2
15
Dec 1, 2004 02:45 PM
bariman1226
Electrical Systems/Wiring
Jan 21, 2003 12:29 AM
