Sponsored by: Real Truck
Tire sensors
Old May 8, 2014 | 03:28 PM
tcat's Avatar
tcat
Tire sensors
I need a little help please. I have a new 2015 f250sc coming in next week. I"m getting bigger tires & wheel right away for summer use only ( will run stock ones in winter ) I have picked out 325/65/18 nittos but they are D rated not E. I'm not going to haul anything heavy so that won't be a problem. Is it ok to run them without sensors? I know light will be on I can live with that. Or can you disconect it? Or I don't mind buying new wheel sensors for the new wheels/tires but will I have to reprogram the computer for the D rated max air 50psi and then re-program back when I put the stock wheel/tires on in the winter? Does any of this affect the running of the truck? Like if I was to not install sensors in the new wheel/tires? Thanks for any help!! Tim
Old May 8, 2014 | 04:01 PM
Kdr358's Avatar
Kdr358
Most tire shops will re-learn for the pressure difference.
There is also a manual re-learn, I have heard about it but never looked into it.
Old May 9, 2014 | 10:01 AM
SuperDutyScaler's Avatar
SuperDutyScaler
i thought after the 2012 year Ford changed the system so it cant be changed any longer....?
Old May 9, 2014 | 10:10 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
I thought it only measured for a sensor reading outside the average of all of them. ie set all the tires at 55psi and the light only comes one when one of them drops down below a certain range?
Old May 9, 2014 | 10:58 AM
Kdr358's Avatar
Kdr358
When I had my 285 duratracks put on they told me if the tps light comes on to bring it back and they will re-learn the sensors. I really don't believe tire shop clowns since he didn't look a day over 16.
I think you are correct about the avg pressure. I keep my E range duratracks at 70 in the rear and 75 in the front.
jerryparks
2004 - 2008 F150
Feb 11, 2019 07:59 PM
Flooringit
Jul 21, 2017 07:59 AM
2008F250SHAKING
Jan 21, 2012 11:26 AM
scrooge
2004 - 2008 F150
Mar 21, 2007 03:52 PM
rfairwea
Feb 2, 2006 01:51 PM
