Sponsored by: Real Truck
Motorcraft SP509 Plug
Old May 7, 2014 | 02:52 PM
2stepn's Avatar
2stepn
I think its time to replace the plugs on my 08 V10, with 62K. The engine build date is 110907 and I have the brown coil boots. With this info. I should have the SP509 plugs in the engine.
My questions: Is the SP509 a 1 or 2 piece plug?
Those of you that have changed plugs in your truck are you still soaking a slightly loosened plug with carb cleaner?
Will any carb cleaner work, gumout etc. or should I get Fords?
Are you changing the coil boots when you change the plugs?
Are you using motorcraft or another brand of plug?
Hopefully plug breakage is not an issue.
Thanks for you help.
Bill
Old May 7, 2014 | 05:00 PM
Kdr358's Avatar
Kdr358
FWIW my 07 E350 had the one piece plug. The "Better ones" is what the Tech told me. I think by the end of 07 The issue was corrected.
Old May 7, 2014 | 07:20 PM
je5's Avatar
je5
1 piece, use factory plugs and change boots.
Old May 10, 2014 | 07:32 AM
2stepn's Avatar
2stepn
Thanks for the info.
boi_hawks
Modular V10 (6.8l)
Jul 3, 2013 06:41 AM
WestxSRT10
Sep 13, 2012 10:29 PM
pjw73nh
17
Sep 2, 2011 05:17 AM
andrewzx92000
Modular V10 (6.8l)
Feb 26, 2007 07:39 PM
VIKING24
May 14, 2005 10:08 PM
