Throwing a push rod
Old May 6, 2014 | 11:05 PM
  #31
JWC 3's Avatar
JWC 3
Originally Posted by jesseh39
Bump the motor. Once the rocker moves tighten the other one?
Turn the motor by hand with the proper socket on the crank bolt . Watch the valve train while turning . Do not " bump " the motor over while working on the valve train .
Old May 6, 2014 | 11:07 PM
  #32
jesseh39's Avatar
jesseh39
And proper way to set the valves? Wait until the one moves and do the other one?
Old May 6, 2014 | 11:19 PM
  #33
JWC 3's Avatar
JWC 3
If I am setting valves , not so often anymore , I wait until the one valve on a cyl. is near compressed . I then adjust the other on that cyl . I work my way down the banks in that order ,marking each with a grease pencil after adjusting .
Old May 6, 2014 | 11:21 PM
  #34
jesseh39's Avatar
jesseh39
Originally Posted by JWC 3
If I am setting valves , not so often anymore , I wait until the other valve on a cyl. is near compressed . I then adjust the other on that cyl . I work my way down the banks in that order ,marking each with a grease pencil after adjusting .
And that's with the zero lash plus half turn at least? And if they are too tight then what does the motor do?
Old May 6, 2014 | 11:26 PM
  #35
BobbyFord's Avatar
BobbyFord
Valve adjustment: One cylinder at a time. Rotate the engine just until the exhaust starts to open. Then, adjust the intake valve on that cylinder to zero valve lash (just until you start to feel drag on the pushrod.) Then tighten an additional 1/2 turn. Lock the lock nut.
Next, rotate the engine and watch the intake valve as it opens and begins to close. Just before the intake valve completely closes is when you adjust the exhaust valve.
Repeat for each cylinder.
Old May 6, 2014 | 11:33 PM
  #36
jesseh39's Avatar
jesseh39
I haven't taken the heads off. I don't know which valve is intake and exhaust. And don't they alternate?
Old May 7, 2014 | 05:55 AM
  #37
nkf's Avatar
nkf
Check push rods for length. How much lift does the new cam have?
Old May 7, 2014 | 06:51 AM
  #38
BobbyFord's Avatar
BobbyFord
[EI EI IE IE]
Old May 7, 2014 | 06:31 PM
  #39
jesseh39's Avatar
jesseh39
K valves adjusted. Now spacing on the spring is a bit tight when it's compressed. It's not as far compressed as the others.
Old May 7, 2014 | 06:59 PM
  #40
JEFFFAFA's Avatar
JEFFFAFA
If you mean the rocker arm is not pushing the valve and it's spring down as far as the rest then that cam lobe is wiped. The cam is junk.
Old May 7, 2014 | 07:11 PM
  #41
jesseh39's Avatar
jesseh39
I will have to measure to be sure. Just eye balled but that's what I'm thinking too
That would also cause it to fall
Apart. Yes indeed it would. Dammit!
Old May 7, 2014 | 07:12 PM
  #42
BobbyFord's Avatar
BobbyFord
Sometimes its difficult to understand what someone is trying to explain through written text.
That's why I said to fish the lifter out with a magnet and inspect the face. I toasted lobe will show up right away on the lifter.
Old May 7, 2014 | 07:16 PM
  #43
nkf's Avatar
nkf
It does not happen very often, I have seen the rocker arm stud pull out and do the same thing.
Old May 7, 2014 | 07:20 PM
  #44
jesseh39's Avatar
jesseh39
Have it in my hand. What is it supposed to look like if it's a bad lobe? Little circle and slightly blue ish?
Old May 7, 2014 | 07:28 PM
  #45
JEFFFAFA's Avatar
JEFFFAFA
As I recall you had a new one in there and then a "good" used one. Look at both and let us know what they look like. Running a used worn lifter can wipe a cam lobe.
