eot and ect
Old May 6, 2014 | 08:48 AM
g tinsley's Avatar
g tinsley
eot and ect
Will the spread between eot and ect temperature be greater when towing a heavy load than running 65 empty Thanks for your reply
Old May 6, 2014 | 10:01 AM
Iaff113's Avatar
Iaff113
My temps go up when pulling. Especially the mountains. But my spreads still stay with in 7 to 9. They Usually run in the upper 190s when pulling flat. My normal spread with out pulling is only 1 or 2 difference
Old May 6, 2014 | 10:10 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Once you're fully warmed up, EOT will be slower chasing ECT down, especially if you start coasting down a hill. I wouldn't worry about "spot checking" your split, look at where it averages when you're not climbing hills and coasting down them. It's not a pass/fail critical fault type deal where the engine blows up if you hit 15*, it's an aggregate failure that builds up over time, and you're looking for variances from your normal to indicate the cooler is clogging.
Old May 6, 2014 | 10:17 AM
MC5C's Avatar
MC5C
yes, there can be as much as a 20 degree difference in a health engine. Very dependant on the load, the speed and the terrain. As noted it's common to have a big difference when you crest a hill and coast down the other side. Coolant drops very quickly with the fan on and no load, and oil follows about 3 - 5 minutes later.
Brian
Medline
Aug 5, 2016 08:32 PM
Mcrafty1
Apr 24, 2016 09:00 PM
tracyclifton
Mar 5, 2015 08:05 AM
jgdrcr
Aug 13, 2014 04:36 PM
jgdrcr
Jun 18, 2014 02:05 PM
