Brighter Tail Lights
Old May 8, 2014 | 04:33 PM
The Masked Rider's Avatar
The Masked Rider
No problem, JMO. You mentioned pulling a trailer. Some trailers have many lights and many with electric brakes, which require upgrades to these old trucks. I've wired a lot of truck that want to pull a trailer. I was just offering an idea. I'll butt out.
Old May 8, 2014 | 06:57 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Shadowrider123
My plan would be to use the 67+ buckets with my 66 red lenses.
Same tail lamps: 1967/72 F100/350 Styleside, 1967/77 Bronco & 1969/74 Econoline.
Old May 8, 2014 | 08:12 PM
theastronaut's Avatar
theastronaut
One thing to remember, you want to keep the buckets so you don't lose the reflector effect if you're parked on the side of the street at night. The LED's on circuit boards block the bucket from reflecting outside light. I've had great results from using fake chrome piant (spraying it "wet" to get the best reflectibility) and new lenses, with fresh bulbs.
A friend of mine has 55 watt headlight/foglight bulbs (H1 or H3, can't remember) in his '57 Chevy's tail lights- keeps the bucket/reflector and is WAY brighter than stock. He's actually melted the lenses sitting in traffic with his foot on the brake. The truck buckets are much larger and deeper so that probably wouldn't be a problem.
Old May 10, 2014 | 05:37 AM
Jeffrey Sutton's Avatar
Jeffrey Sutton
I second painting the bucket gloss white made a huge difference on my 66 mustang, alot brighter than chrome
Old May 11, 2014 | 11:04 AM
daveengelson's Avatar
daveengelson
IMO, nature of the beast, found majority of the electrical gremlins can be traced to poor ground. Also, for those of us who still have the pressure type brake switch not sure getting full voltage to the bulbs?? Suggest clean brake pressure switch connections and all ground surfaces of dirt, grim and paint; especially re: brake housing and lamp, perhaps add a dab of dielectric grease to the ground point locations??
http://i300.photobucket.com/albums/n...WireDiagP7.jpg
Posting link to couple articles that may, or may not be of any help. With my 65 it's not as much an issue with tail lights as with the brightness of the headlights, always kept on hi and still look weak??
Whiter Whites, Brighter Brights | Ford Trucks
Old Trucks: Using Relays to Control High Amperage Circuits | Ford Trucks
Old May 11, 2014 | 10:40 PM
Shadowrider123's Avatar
Shadowrider123
Im running a 100amp Taurus internally regulated alternator. I run the headlights off relays.
My headlights are very bright and do not dim when I let off the gas.
Prior to the alternator and relay upgrade they would dim when the rpms dropped to idle.
Im going to paint my buckets bright white, and rebuild the harness or grab one from the Pull-A-Part.
Anytime you cut a wire, it is exposed to moisture, either in the form of water or humidity. Over time, the wire will corrode. The corrosion may or may not be visible to the eye.
In the case of my truck, I think the tow hitch was installed in the 60s or 70s. As a result of hacking into the harness for trailer lights, the wiring harness is in pretty poor condition. That is probably one of the sources of the poor light output of my tail lights.
Easy fix, just have to get time to do it.
VONxRUBENxLA
Sep 17, 2012 10:07 PM
bhmudder11
Appearance & Dress-Up
Feb 6, 2009 06:45 PM
tlb
May 30, 2006 03:39 PM
Jag Red 54
29
Jun 14, 2005 05:13 PM
Racerdave
Mar 2, 2003 01:06 AM
