Well I was farting around with torque last night and must have left the key in a bit too long. The truck was dead this morning.
After a quick call to AAA (That's AAA aye, for our Canadian brethren) and it was no problem. The guy did mention the batteries looked like they had been boiling, and he indicated a film around the cell openings.
What is boiling? Something I need to fix?
And if someone can provide a 6th grade science level explination that'd be great too. (Hey, school standards are pretty high these days)
Boiling happens when the alternator is putting out to much voltage and it overcharges the battery's, I would check the output and if it is within range I wouldn't worry about it. It could just be residual from sloshing around..
I doubt using Torque killed your batteries... probably something else is happening. If you've got a clamp ammeter, check your system for phantom loads.
There are no phantom loads. And it wasn't torque. It was sitting in the truck with the key on all night while I used torque.
You'd be referring to output voltage right? Not amps? I'm not fantastic with electricity haha.
System voltage us usually 13.5-14.0, if that counts, or do I need to pull out a multimeter and measure right from the alternator?
Yes I was talking voltage and it looks like you are right where you should be, If you haven't been having any problems then I wouldn't worry about it. Like I said probably just junk on top the batterys..
Thats kinda what I figured.
Originally Posted by Ltngdrvr
It's not necessarily too much voltage, but the alternator not cutting off when the voltage regulator senses the batteries are fully charged.
So, voltage output can be okay, but it is charging too much due to a bad voltage regulator.
How would I be able to see this? Wouldnt that mean the batteries would go over 14v? I havent seen over 14 in a while.
Boiling is an overcharge for extended time. If it's cold batteries have high resistance so 14 might be too low. But if it's warm out, engine is hot, a voltage regulator is supposed to adjust charge downward. In practice though, if a battery has "boiled" this means water probably has to be added to replace that lost, to keep the electrolyte above the plates on a "standard" battery. Batteries lose water but normally slowly.
Would be a good idea to test the battery too, depending on the design it may be paperweight. And straighten out the charging system first, before replacing the battery, or may run into the same problem. This is important too because of the gases produced as the normal product of charging a battery. A low electrolyte level may be more susceptible to internal arcing. Bad deal. Keep batteries topped off and charging correctly.
I havent had any electrical problems related to batteries in a long time. These are fairly new. I'll have them tested I suppose. I had them tested not too long ago. Drivers side was fine, pulling more than the 850cca it was rated for, the pass side had 1 marginal cell, and pulled 800cca.
Batteries should be replaced in pairs ! One marginal battery can ruin a good one ... I see that often . Best of luck !
Yes, I know. But neither battery was "bad" so neither got replaced.
The tow truck driver tested them today, and he said they checked out okay on his machine. Ill take them to interstate and have them tested to be sure, but I doubt they will be getting replaced. I dont see a problem here with them. I just left the truck on too long. I just wanted to know what boiling meant. And now I know.
