1986 Ranger
Old May 5, 2014 | 01:18 PM
1cooltruck's Avatar
1cooltruck
1986 Ranger
I am in the process of restoring a 1986 Ranger and i need to replace both window motors. does anyone have experience in removing them? Any help is appreciated. thanks
Old May 8, 2014 | 08:20 AM
tomw's Avatar
tomw
You may have to drill some access holes to remove the mounting nuts. After you remove the latch lever screw, armrest, use a wide blade to pull the inner panel off. There will be a 'humidity shield' held in place with black goo. Remove it carefully, and watch for getting the goo all over. It will drool.
Now you can see into the door. Look for a dimple in the sheet metal immediately outside of where the motor & regulator are mounted. I had to drill one out for access using a 1/2" drill bit I think. The new motor came with instructions and possibly a plastic plug. It was over 20 years ago, so memory is a little vague. I think you can use tape, clear plastic packing tape or duct tape to hold the window glass when the motor is removed from the regulator.
If this is not enough, let me know.
tom
Old May 8, 2014 | 09:42 AM
Old93junk's Avatar
Old93junk
There is very little room to work inside the Ranger doors, and sharp edges, bring band aids.
Old May 8, 2014 | 10:06 AM
1cooltruck's Avatar
1cooltruck
Thank you for the help. I will post when finished how it went.
cato47
19
Jan 3, 2012 09:19 PM
dgeesaman
Dec 6, 2009 07:06 AM
mirroman
Mar 21, 2006 08:29 AM
wcbrown
Electrical Systems/Wiring
Dec 20, 2004 09:50 PM
rpg1120
Nov 12, 2003 12:56 AM
