No power to the cig lighter or OBDII - Not a fuse...
Hello,
99 V10 4x4 F350. I have no power to the cig lighter (power port works fine) or OBDII. The fuse is fine, but I changed it 3 times just to be safe. No change. I have the entire dash pulled apart as i figured somewhere along the way someone might have hacked something, but everything looks perfect. Just as it left the factory.
Are there any other gotcha's I should be looking at?
Thanks,
Chris
Thanks,
Chris
Will let you know.
Thanks.
Anyone have a detailed wiring diagram?
Pull the fuse (F3, 20A) and check to see if you have "ALWAYS HOT" power on one of its terminals in the box. check the contacts for spreading or other damage. If you do not have power there and everything else in the truck works properly, then it's a failure internal to the fuse box.
If one terminal does have power, identify it as your source terminal, the other will be the load. The load terminal, with the fuse removed for testing, should have continuity to both the OBDII port and the lighter via splice S242.
