Loose Front End?
Old May 4, 2014 | 12:45 PM
Kingkong0192's Avatar
Kingkong0192
Loose Front End?
1997 Ford F250 7.3. TTB-50 Front end.
Truck ate the front tires.
Jacked up the front end to get the tires off the ground and shook the tires at 12 & 6 and 3 & 9 and there was a bunch of noticeable play in both directions.
What's the most likely culprit?
- Wheel bearing?
- U- Joints?
- Ball Joints?
Ball joints were done about 2 years ago (put maybe 15-20,000 miles on the truck.)
U-Joint were done about 6 months ago.
Anything else i'd take is from the factory or from the previous owner.
Found a tapered roller bearing on Advance autos website. That seems to be the only "wheel bearing" i can find for this truck. Is that the only one in there? Any special tools needed to change it?
Old May 4, 2014 | 12:51 PM
Chris56ford's Avatar
Chris56ford
lost
The 12 & 6 are probably ball joints. The 3 & 9 is probably tie rod ends.
Old May 4, 2014 | 12:59 PM
Kingkong0192
They got done roughly two years ago (15-20k miles). Does the TTB-50 really eat through balljoints that fast?
I'll go take a look at the TREs and see if i can see any play in them.
Old May 4, 2014 | 01:06 PM
Chris56ford
lost
Usually not that quick, but I have seen it happen. Depends on what brand they were and if they were greased regularly. If there is lots of play, you should be able to see the ball joints move when someone wiggles the wheel/tire.
Old May 4, 2014 | 01:17 PM
Kingkong0192
3 & 9 is defiantly worse than 12 & 6.
I'm not exactly sure how, but with the tire like 1/2" off the ground (passenger tire) and the driver tire still on the ground shaking the tire at 3 & 9 is shaking the driver tire. I didn't think a bad TRE could cause this to happen.
I can't see any play in the ball joints or TREs. It's like the wheel is just shaking on the hub. (Like a loose/not tight enough bearing.) Is that even possible or am i rationalizing things here?
Here's a video.
Old May 4, 2014 | 01:26 PM
Chris56ford
lost
The video helps a lot, thanks. It doesn't look like ball joints from the video. The wheel is moving separate from the brake shield. I'm sure you have checked lug nut torque already?
That is really loose. Are both side like that? If lug nut torque is good, I would check the spindle nut behind the hub, it might be loose. The cotter key might be gone or broke and fell out.
With it that loose I would think you would hear noises in the front end while driving.
Old May 4, 2014 | 01:40 PM
Kingkong0192
Welcome. Happy to hear i'm not crazy. Haha.
Lugs are tight. I was looking at it like why is it like this tire is just loose and not tight on the hub? Other side is totally tight. No play at all, tire is fine.
I just removed the three torx bolts that hold the locking hub thing on (don't know the technical names for any of this. Sorry. Haha)
I used two flat head screwdrivers to remove the snap ring then i pulled that piece out.
What "cotter key" are you talking about?
I then used a flat head screwdriver and a hammer to loosen the spindle nut (not sure again on terms) and needless to say it wasn't even hard to remove. After that came out, i removed another spacer, then another one of those nuts. Neither of which were tight.
I then pulled out the tapered bearing. Going to buy a new bearing now, and the special tool to tighten those spindle nuts.
Do you know the actual torque spec on them so i can torque them correctly? (Or does this have one of those weird dial gauge torque specs where i tighten the nut, then spin the wheel until it has a certain resistance to it?
Thanks again dude!
Old May 4, 2014 | 01:44 PM
Kingkong0192
Old May 4, 2014 | 02:00 PM
Chris56ford
lost
Cool, looks like you found the problem. Sorry I meant cotter pin. Is there a hole in the spindle where the nuts go? I can't remember now lol.
On the torque specs, the inner nut tq is 50 ft lbs then back it off a 1/4 turn. Then put the lockwasher so the key is positioned in the slot, tighten inner lock nut so the pin is aligned to the nearest hole.
Outer nut torque is 160-204 ft lbs.
Old May 4, 2014 | 02:07 PM
Chris56ford
lost
Nevermind on the cotter pin, it's not suppose to have one.
Old May 4, 2014 | 03:07 PM
Kingkong0192
Alright got the bearing packed with grease and installed.
Put the inner nut back on. Torqued to 50 ft/ibs, then backed off 1/4 turn. (Felt loose, but if that's the torque spec i'm not going to change it.)
Got the lockwasher positioned so that the key is in the slot. I do not know what you mean by "tighten inner lock nut so the pin is aligned to the nearest hole." Could you please elaborate a little bit on that?
Does 180 ft/ibs sound good for the outer nut?
(That slot is at like 11 o'clock.)
Old May 4, 2014 | 03:40 PM
Chris56ford
lost
The inner nut needs to have the little pin facing out. Then the washer goes in. The pin on the inner nut needs to align with one of the small holes in the washer. So you would tighten the the inner nut to align it instead of loosening it. It may already be aligned and you didn't notice. But def make sure the pin on the inner nut is facing out. I attached a pic of the nuts and the washer. See the pin the on the nut on the right? I would stay at the higher end of the specs on the outer nut, maybe 200 ft lbs. Don't want that thing loosening up on you again!
Old May 4, 2014 | 11:00 PM
nateairman's Avatar
nateairman
I have this exact problem!
A shop rebuilt that side less than a year ago. I bought new bearings and seals to do the work myself but was unsure what could be wrong. Thanks for the info now I know what to fix!
machinist91
Jul 14, 2013 11:55 PM
mikecox1
1997 - 2003 F150
Apr 2, 2009 01:37 PM
'04 PWRSTROKE
Jul 21, 2007 11:32 AM
03 Maz B23
1983 - 2012 Ranger & B-Series
Feb 20, 2005 04:58 AM
200solomiles
Feb 12, 2005 10:48 AM
