door lock cylinder replacement??
Old May 3, 2014 | 08:08 PM
centralNH's Avatar
centralNH
Is there any advice or videos on changing door lock cylinder on our trucks? I have never had a door key for my 69 and ordered a new set today. Not like my newer truck where clips are on door jam not inside door like ours.
Old May 3, 2014 | 08:31 PM
orich's Avatar
orich
Remove door panel while window is up then remove fork type clip holding key lock cylinder in place remove linkage to lock button. Piece of cake..
orich
Old May 3, 2014 | 08:36 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Old May 3, 2014 | 08:41 PM
orich's Avatar
orich
Removing door trim panels isn't going to help, because the clips that retain the lock cylinders are located on the outside of the doors. Peel back the door weather strips to locate them.
What if theirs no inner door trim and only has a panel like some do & some do.
Plain Jane typy then who's right both!
orich
Old May 3, 2014 | 09:47 PM
Gembone's Avatar
Gembone
no trim on mine. remove the window handle and armrest. then remove the screws for the inner panel. then if you have the paper backing, remove it. then take some pliers and pull the U clip and out pops the lock. Takes about 10 minutes on mine. Very simple. Be sure to keep the action arms off the old locks. they are usually different then the ones on the new locks but switch over.
1996X
Feb 15, 2011 02:21 PM
F150&EB
1997 - 2003 F150
Aug 18, 2006 08:00 AM
Pablo-UA
Aerostar
Dec 27, 2005 11:18 AM
aerovan
Aerostar
Jan 14, 2005 06:12 AM
Lazy P
Jul 23, 2004 12:23 PM
