. Actually, the old cam should have power to 5000+, the new cam to 5500+...
. Both cams should have some lope at idle, but not as noticeable in a lower compression ratio 2 bbl. engine... as in a 11.0:1 engine... or if idle RPMs set higher...
. Cam companies usually conservative on RPM range because they don't know what kind of slug engine someone might put it in... most early to mid 1970's engines only had an actual compression ratio in the 7's... usually listed as a nominal '8.0:1' or '8.5:1' by the vehicle manufacturer... those vehicles with V8's got about 9 - 13 MPG... even 1990's Jeep Cherokees gov't rated 9 MPG city, 11 MPG hiway with 360" V8...
282/292 on 112 lsa is 63 degrees overlap
260/260 on 110 lsa is 40 degrees overlap
23 degree overlap difference. Which is 23 degrees of air and fuel escaping the cylinder. Fuel being lost, as well as air being lost and losing compression.
Could it be the possibility that my fuel pressure is too high and blowing past the needles?
. Do you have other than a stock fuel pump?
. If floats adjusted incorrectly and hit carb. body before shutting off fuel flow, that could mimic that problem...
. Never shake a carb. "to see if float rattles", turn upside down gently and slowly... can bend float adjustments... as can UPS/Postal/FedEx employees throwing the carb./box the length of an 18-wheeler trailer... we were required to do that when I worked midnights for UPS while in college... TV's too...
I could try to take a comp test on the old motor, not sure I could spin it fast enough though.
I've been trying my damnedest to keep speed low and go easy on the pedal. But I just got back from a 70 mile trip and netted 12.2mpg. That just ain't gonna cut it.
. And a fuel pressure gauge to see what's happening... I picked one up for $5 at a fleamarket swap... think I'll also get a MPG meter and a fuel/air mixture monitor... got lot's of vehicles/engines to play with...
What about going to a smaller carb? I've got the 600 now, but I know I'll never even use the full of that. A 500 would be more appropriate. That would help mpg too right?
. When you get into carb.'s smaller than 650, you also tend to get into idle circuits too small for 351" engines...
. The primaries in a 600 4bbl. are smaller and more efficient than some 2 bbl. carb.'s... you're prolly using about all a 600 has on that 351C with 204/214 cam when you get on it a bit...
