Sponsored by: Real Truck
Fuel filter/line tips??
Old May 3, 2014 | 04:41 PM
luv2offroad2's Avatar
luv2offroad2
I have a 2000 F250SD with 96k miles that I purchased a few months ago. I'm pretty sure the fuel filter has never been replaced as it is rusted pretty good. I cannot get the fuel lines disconnected from it - even broke the metal quick disconnect tool from Pep Boys. Is it possible that the fuel lines are rusted and therefore making it harder to get off? Any advice on how to get them off easier?
Old May 3, 2014 | 06:13 PM
Jnowaczyk's Avatar
Jnowaczyk
try spraying pb blaster or wd40 let it soak a bit
Old May 3, 2014 | 06:34 PM
Wolfboro's Avatar
Wolfboro
Try a different brand /style "disconnect tool" . I had the similar problem .
Old May 3, 2014 | 06:47 PM
luv2offroad2
Thanks. I was thinking about the PB Blaster but wasn't sure if that was ok to do on the fuel filter area. I'll go out and spray that on now.
And I'm glad to hear someone else has had one of those tools break. I specifically got a metal one so it wouldn't break. I picked up another style and I'll try that one.
Old May 3, 2014 | 09:22 PM
Jnowaczyk's Avatar
Jnowaczyk
they can be a pain i push my tool in while pushing and pulling the line back out tool should follow you once your spay has time to work push the tool in while holding the line a few times befor pulling should come
Old May 4, 2014 | 10:48 AM
galaxie641's Avatar
galaxie641
Plastic ones come in handy where you can push them in and then spin them around. Sometimes you need to use the metal and sometimes you need to use the plastic ones. I'd spray with penetrating oil for several days and spin the connectors each time.
Old May 6, 2014 | 11:44 AM
luv2offroad2
Well, I've sprayed the connectors twice now and still can't get those things to budge. Maybe it's because I'm a whimpy girl. LOL I'll keep trying until they come off.
Old May 6, 2014 | 12:14 PM
hpwoee's Avatar
hpwoee
fuel lines will not come off until you have your mouth open and head below filter and line... that's just my personal experience.
Old May 6, 2014 | 12:29 PM
CollinsCD's Avatar
CollinsCD
LOL..... Too funny!
Old May 6, 2014 | 12:31 PM
luv2offroad2
Oh, that's my problem. Here I was laying at an angle as to get the least amount of fuel on my face the whole time.
Old May 6, 2014 | 12:39 PM
r2millers's Avatar
r2millers
Once you get the 5/16" tool around the fuel line, you really need to push in pretty hard into the end and pull the connector at the same time.
Doesn't take big biceps to accomplish, just turn your head at the same time.
Old May 6, 2014 | 03:57 PM
1977cutcher's Avatar
1977cutcher
Very rarely does a fuel filter seem to go easy for me. I generally end up using foul language to work it loose. I have always used the plastic slip on tool; perhaps that is my problem.
dpoc
Jul 29, 2021 12:32 AM
2002exPSD
33
May 16, 2011 11:29 AM
itsafordguy20
Jul 31, 2007 10:51 AM
bass4163
1978 - 1996 Big Bronco
Jun 23, 2006 11:24 AM
fshoffner
13
Jan 27, 2000 12:59 PM
