AC problems
Old 05-03-2014, 08:56 PM
blsaoo86's Avatar
blsaoo86
blsaoo86 is offline
AC problems
Upon receiving my truck I was told that the last two fan blower settings dont work then would blow a fuse. I need help as to find out what my issue could be. Also the max ac setting would blow the fuse as well. Thank you.
Old 05-05-2014, 03:37 PM
je5's Avatar
je5
je5 is offline
Sounds like the blower motor needs replacing and I would replace the resistor block with it as well. Hopefully you will not need the dash switch.
Old 05-05-2014, 03:41 PM
blsaoo86's Avatar
blsaoo86
blsaoo86 is offline
Just replaced the resistor an! Its working now. Thanks for the help
Old 05-05-2014, 05:52 PM
je5's Avatar
je5
je5 is offline
You are welcome. And welcome to the forum.
clint39
09-12-2012 09:36 AM
paulwjax
06-18-2011 12:55 PM
bigtexan99
13
05-30-2011 09:28 AM
lanncz87
1997 - 2003 F150
09-04-2010 08:32 PM
poffutt
1978 - 1996 Big Bronco
09-05-2007 01:57 PM
Quick Reply: AC problems
