another project in waiting perhaps
Old May 2, 2014 | 06:54 PM
havi's Avatar
havi
I'll have the Roast Duck
Well, I recently picked up this '46 chassis. Don't exactly know why, other than I had $150 burning a hole in my pocket.
That said, I wouldn't mind finding a '40/41 tonner body for it.
Old May 3, 2014 | 12:45 AM
GB SISSON's Avatar
GB SISSON
Very nice score Havi. You need that front clip from Missouri. You could build it one piece at a time, Like Johnny Cash's cadillac.
Old May 4, 2014 | 09:40 PM
havi's Avatar
havi
I suppose I could! lol.
I've got a 59a V8 and older 4sp. I could use. Some time soon, I'm going to pick up the gas tank and other parts that go along with this truck for a 12 pk of diet coke. Not a bad deal.
Yesterday I went to French Lake Auto Parts, and though they didn't have anything for 40/41 truck body parts, I did spend a lot of money for some other projects. That place is crazy cool!
Old May 4, 2014 | 11:01 PM
GB SISSON's Avatar
GB SISSON
I have some parts you could use but the shipping is a killer. Some half-decent '39 tonner front fenders and a '38 hood and side panels. Wish we were closer.
Old Jun 13, 2014 | 08:53 PM
havi's Avatar
havi
that 12pk of diet coke got me the gas tank, instrument cluster, floor shifter, some other small parts, and most importantly... 4 hubcaps.
Old Jun 13, 2014 | 10:30 PM
GB SISSON's Avatar
GB SISSON
The tonners have the coolest hubcaps. Do they say V8 or Ford? After they brought out the inline six, they changed the tonner's hubcaps. Not sure when that was. This might not be a bad way to build a truck. You will know the condition of each part, as opposed to pulling one apart and finding no flange left on the rear fenders, or floormats with no floors underneath.....
Old Aug 10, 2014 | 07:18 PM
havi's Avatar
havi
Some details on the chassis I got.
1946 Ford tonner, 122" WB standard, but the rear frame is bobbed for a dump bed, along with the bracketry welded to the frame for holding twin lift cylinders.
Rear axle is the stock split Timken with 4.857 gears.
Wheels are stock 17's 5x6.875 BP, with the meaty rears, and newer fronts (radials I assume) that don't sit right, so I need two front tires.
Steering column is intact, as well as short running boards, but there's no engine, trans, or body sheet metal. Really not sure what I'm going to do with it yet. I have enough irons in the fire as is.
That said, if a tonner panel body becomes available, I'm all ears.
havi's Avatar
havi
One possibility is to make a small metal dump box for firewood or scrap metal, based on Stu's diagram from my other thread https://www.ford-trucks.com/forums/1...-diagrams.html
I have one other option up my sleeve, but I won't reveal that until it actually becomes real.
Old Aug 10, 2014 | 08:53 PM
truckdog62563's Avatar
truckdog62563
Marmon-Herrington Man
Does it have clean paper? If so, does the VIN on them tell which plant produced it? Stu
Old Aug 10, 2014 | 09:11 PM
havi's Avatar
havi
no title, but the serial number on the frame is legible.
Old Aug 10, 2014 | 09:23 PM
truckdog62563
I have a hair brained project idea too, but Ill-annoy makes it a giant pita if you don't have a straight path to get it legal. Plus, my project would require a HM, CH, or LU VIN. Stu
Edit - looking through one of my books, I wonder did the 47 and earlier trucks not have the production plant in the VIN? Stu
Old Aug 10, 2014 | 10:26 PM
GB SISSON's Avatar
GB SISSON
It's always good to have a title with any truck. It can be a long process to regain one that is lost.
Old Aug 10, 2014 | 10:27 PM
38 coupe's Avatar
38 coupe
The 47 and earlier trucks did not have the production plant in the vin. In those years the vin was based on the number stamped on the transmission when the engine / transmission was built. Typically this happened at the Dearborn plant. Then the engine / transmission was shipped to an assembly plant (or used at the Dearborn plant). When the engine / transmission was installed at the assembly plant the transmission number was stamped onto the frame and became the vin. Vehicles came off the assembly line out of order compared to their vin... it must have caused confusion.
Old Aug 11, 2014 | 12:11 AM
GB SISSON's Avatar
GB SISSON
Having people to help with decoding vin numbers is a very valuable service on FTE, and the eventual re-titling process!
Old Aug 11, 2014 | 08:38 AM
truckdog62563
Thanks for the clarification. That will simplify things if I decide to do a "late in life" M-H conversion to a tonner. Stu
