Valve cover clearance
Old Jul 6, 2003 | 02:23 PM
himmelberg's Avatar
himmelberg
Originally posted by fatfenders
So now you're saying your shaving all the emblems off your truck too?
Read 'em and weep.
Best. Himmelberg
Old Jul 6, 2003 | 08:01 PM
cabby daddy's Avatar
cabby daddy
peter,
Do you have access to a "porta-power". It is always better to push, than to pull... with a porta power you can slowly move the metal where you want.
Robert
Old Jul 6, 2003 | 08:13 PM
Kurt G.'s Avatar
Kurt G.
Peter reguarding my motor being backwards that might explain why I have 1 forward gear and 4 reverse gears. Are those side emblems for the hood 54 or 55. Kurt y-blocks rule!
Old Jul 6, 2003 | 08:42 PM
himmelberg's Avatar
himmelberg
Robert... don't know about "porta power". Is it like a jack? Can I borrow one down at the AutoZone? I've got a big crowbar and just about enough room to lever it against the block.... Oh, and, as usual, 'fenders is right about the heartiness of the firewall sheetmetal. Stout stuff.
Kurt... the side emblems are for a '55. I'm guessing I've got the hotrod '55 hood on my '54. The grille emblem star is for the '54... but signifies a 6 cylinder engine, but, lurking in there is the manly 292 with the single T-bird valve cover and exhaust pipe carb. The hood emblem is probably correct but isn't as colorful as the Brazilian version.
I like Ozzie's suggestion. I'm checking my attach points for a little slack. I like the idea of pushing sheetmetal like Robert says. I like Kurt's backward engine. I like being an eFriend. Thanks guys. Himmelberg
Old Jul 7, 2003 | 10:35 AM
Big Hands's Avatar
Big Hands
Peter
A Porta Power consists of a hydraulic ram cylinder and many fittings that allow you to spread, jack, raise or do any number of things to metal. Some of the auto body shops use them and some of the local fire departments have one. Are you friends with a volunteer fireman?
Auto Zone may or may not have one for rent. Maybe your local rental center place may have one... Good luck
E-friends huh? I kind of like that..
Hot as the main strret of Hades here today!
Sweating hands
