initial starting issues when cold
Old May 1, 2014 | 06:31 PM
joe blow's Avatar
joe blow
Hi guys,
Need a little help. 2005 6.0 and the truck has been progressively getting harder to start lately. No stumble at start up but excessive cranking is also begin to lengthen for the truck to start.
Does it sound like a HPOP problem to you guys or FICM problem. No codes at all. The truck belongs to a friend but I don't know any other specifics. Any diagnostic ideas are welcome
Thanks
Old May 1, 2014 | 07:23 PM
diesel_dan's Avatar
diesel_dan
Can you get your SGII over on his truck and check it on cold start?
If I was guessing (I think I am): FICM would be the first one... But then how are the Batts and Alt?
So many things, so few friends...
Old May 1, 2014 | 07:28 PM
78fordman's Avatar
78fordman
2nd the FICM and then possible HPOP problems. Try parking nose up and then nose down and see if it helps the starting. Need to know FICM voltage during cold starting and ICP and IPR too.
Old May 1, 2014 | 07:34 PM
diesel_dan's Avatar
diesel_dan
Good point as well -- so how are his hot starts? W/ the '05+ HPO system I'd start looking for things like STC and the like...
Old May 1, 2014 | 07:51 PM
joe blow's Avatar
joe blow
Thank you guys. He just had the STC's updated and the FICM replaced a few years ago. I have to see what I can do about getting some of the info. My SGII is permanently (or close to it) mounted in my dash.
Old May 1, 2014 | 08:52 PM
BLADE35's Avatar
BLADE35
Looks like the guys have a good start Joe
My SGII is just about permanent in my dash I have to fish the wire evey time I pull it to help fix a truck
Still at the Fire department?
Old May 1, 2014 | 10:10 PM
joe blow's Avatar
joe blow
Hi Benny,
Been gone a while doing dad $h*t and well you know. I see you're racking up the rep points my brother....you deserve it man, you know your stuff.
Regarding the fire department....YEP, still there.....I will be there for life (or until I get too old and they say GTFO!)
Restlesswildman
Dec 8, 2013 11:13 PM
beckman
Dec 22, 2011 11:44 PM
larchy
Jun 24, 2010 01:55 AM
stroke-of-luck00
Mar 3, 2009 07:47 PM
