Yet other question.
Old May 1, 2014 | 05:00 PM
RadioControlGuy85's Avatar
RadioControlGuy85
Yet other question.
ok guys.
we got a motor back together,but the timing is off.
could anyone tell me what the timing is? and how to get the right timing?
thanks
Old May 1, 2014 | 06:38 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
Base timing is 10° BTDC.
You need to put #1 at TDC and install the distributor with the rotor pointed at the #1 terminal on the cap. I can peek in in the valve cover with the oil filler cap off while turning the engine by hand and see when the intake valve opens/closes. Once it closes use a dowel or whatever in the spark plug hole to determine when the piston is at the top of the bore. Engine will turn much easier by hand if you remove all the spark plugs.
Old May 2, 2014 | 09:06 AM
1986F150six's Avatar
1986F150six
Concise answer, BaronVonAutomatic. Good job!
Old May 2, 2014 | 08:02 PM
RadioControlGuy85
thanks.info we got her fired up and runing.
cjcloward
Aug 18, 2017 07:57 PM
dionysius
18
Jun 12, 2017 06:45 PM
Arizona84F150
May 4, 2017 10:03 PM
howdy71475
16
Oct 15, 2012 06:13 PM
Bovaloe
Feb 17, 2010 10:33 PM
