smoking after studs & delete
Old May 1, 2014 | 02:06 PM
highpointstroker's Avatar
highpointstroker
So I've been having problems that 98% of 6.0 owners have. It started out with just a lot of smoke while always having power just smoke. I installed the blue spring kit and only mods are 4in tbe intake and sct with innovative tunes. So I took it to a local guy who installed new oil cooler, egr delete, a1 studs, egt probe, coolant filter, and all supporting equipment such as gaskets, etc. So I get the truck back and immediately change the tune back to the custom. Noticed the smoke train continues to roll. Truck still has a ton of power but also a ton of smoke and can't find the problem. All white smoke too... anybody else have this issue
Old May 1, 2014 | 02:37 PM
Lx460's Avatar
Lx460
Did you have a failed erg cooler? Sometimes it takes a while to burn off after repair. Pull the erg valve and see if it's a nasty mess in there.
Old May 1, 2014 | 02:40 PM
highpointstroker
Yeah it had gone bad and yeah there was a mess after I took the egr valve off. But it's still blowing smoke as if the cooler was still on and busted
Old May 1, 2014 | 02:42 PM
highpointstroker
Could I pull the block off plate off and pour some seafoam down while it's running to help speed the process up
Old May 1, 2014 | 02:49 PM
steelhead2's Avatar
steelhead2
Dont do that. Tons of white smoke?, sounds like a stuck injector. Does it smoke when its returned to stock?. What kind of programmer you running.
Old May 1, 2014 | 02:51 PM
steelhead2's Avatar
steelhead2
Also pull the turbo down pipe off and check for oil in The exhaust pipe.
highpointstroker
Running a sct livewire. & it still smokes just not as much. I was told that two injectors were sticking before but thought it would have a rough idle, and misfire
Old May 1, 2014 | 05:44 PM
steelhead2's Avatar
steelhead2
Not necissarily. Better get them fixed before you have no idle and hydrolock.
Old May 1, 2014 | 06:13 PM
highpointstroker
So can I change only the bad ones if I remain oem?
Old May 1, 2014 | 07:44 PM
78fordman's Avatar
78fordman
Sure can. What year of truck? IIRC the 03 trucks had a different factory injector than newer trucks. The newer injector could be used if the whole set was changed. Something different with the intensifier piston i believe.
Old May 1, 2014 | 07:47 PM
highpointstroker
Normally I wouldn't mind buying all 8 but I just got the truck back from a head stud job. Its an 06. What's the tool used to check if they're sticking?
Old May 1, 2014 | 07:51 PM
78fordman's Avatar
78fordman
Are you getting any cyl contribution codes? A power balance test may help too. If one is stuck open maybe pull the injector wires one at a time, the one that does not make any or little difference would be the culprit. Also keep in mind a $150 diagnostic at the dealer may save a bunch of headaches.
Old May 1, 2014 | 07:58 PM
highpointstroker
I actually had a diagnosis done not to long ago that said which ones it was so then I did the blue spring and rev x and no problem any more. I'll look for the report if I still have it but I'm getting rev x tomorrow and going to talk to a mechanic about changing those injectors
jasoncar40
Nov 9, 2009 11:41 AM
jwhittle11
Sep 24, 2008 11:28 PM
jkpenny376
Mar 6, 2008 12:11 PM
glm racers
Oct 16, 2007 05:18 PM
badbrad60
Feb 2, 2007 10:32 PM
