Minnesota Chapter Join Chapter, Leader: fordpower88
May BS Thread.....
Old May 8, 2014 | 03:57 PM
  #241
fordpower88's Avatar
fordpower88
Quiet in here!
Old May 8, 2014 | 04:01 PM
  #242
wildstang's Avatar
wildstang
VT Chapter Ldr
Guess nobody is home.
Troy I have a pressure washer question. My father in law pressure washer is s not bypassing the water when sitting idling. Keeps building pressure loading the engine. Is there a bypass valve stuck?
Thanks for any help
Old May 8, 2014 | 05:01 PM
  #243
fordpower88
Jim the unloader valve is stuck. The red **** you see there is where the unloader valve is located underneath it. The red **** is used to set the pressure. More than likely you are going to need an unloader kit. Sometimes you can pull it apart and use a little grease to lube it up but that usually is just a quick fix if it even helps.
Old May 8, 2014 | 08:10 PM
  #244
wildstang's Avatar
wildstang
VT Chapter Ldr
Thank you Troy I'll check it out. Does it just screw out? Anything to watch out for when taking it apart?
Old May 8, 2014 | 08:32 PM
  #245
DieselCamper01's Avatar
DieselCamper01
Evening guys.
We have officially bailed on the weekend camping. Sorry.
Old May 8, 2014 | 08:50 PM
  #246
fordpower88
The red **** will either screw off or just pull off and then you will get to the main part that will also screw out. Just pay attention in case there are any loose parts such as a spring, washers etc. You might be able to look up the brand of washer with the model number online and find a parts diagram online.
Originally Posted by DieselCamper01
Evening guys.
Evening Jay! Well that sucks! I take it Lynn isn't going to be up to it?
Old May 8, 2014 | 09:08 PM
  #247
DieselCamper01
More that my truck isn't and all the other crap going on we just said the heck with it this time. Too much BS for everyone to get us there and back home. I do appreciate the offers though.
Old May 8, 2014 | 09:09 PM
  #248
MisterCMK's Avatar
MisterCMK
Hello everybody.
I had the pleasure of replacing the tie rod ends on my pickup. The alignment is close enough. LOL
I was going to replace the drag link end link at the knuckle but I didn't want to horse around with trying to get the steering wheel centered. I'll probably order a drag link as well. That should be all of the steering joints on the truck then.
Old May 8, 2014 | 09:10 PM
  #249
DieselCamper01
Looks like NAPA has the steering box for about $165.
Old May 8, 2014 | 09:14 PM
  #250
fordpower88
Gotcha! Would be glad to help get your camper there but understand. Maybe drive out for a visit.....
Originally Posted by MisterCMK
Hello everybody.
Hey Chris! Sounds like fun.
That doesn't seem to bad.
Old May 8, 2014 | 09:18 PM
  #251
DieselCamper01
Yuck Chris!
Yeah, I think that may just be the project this weekend. yay...
Old May 8, 2014 | 09:28 PM
  #252
DieselCamper01
Anybody think one of these would be better than the other?
Cardone® Remanufactured 27-7569 - Steering Gear Box | O'Reilly Auto Parts
NAPA AUTO PARTS
Old May 8, 2014 | 09:56 PM
  #253
Bigpipes 35's Avatar
Bigpipes 35
NAPA AUTO PARTS
Here is the result of my parts house steering gear, I now have the Redhead box and so far so good. I know the guys have had ok luck with the parts house one just not me..
Old May 8, 2014 | 10:02 PM
  #254
msmenne17's Avatar
msmenne17
Good evening everyone ... finally done with this semester. This class sucked!!!! That was a LOOOONNNNGGGGG 8 weeks.
The professor is obviously extremely smart about the field of finance and investments. When it comes to actually teaching it .. that's a different story. If I got 50% on the final, I'll consider that a gift. We'll see what the curve ends up being.
Done with that class. The material will come back to haunt me in a future class ... I've already been warned.
How is everyone here?
Old May 8, 2014 | 10:26 PM
  #255
wildstang's Avatar
wildstang
VT Chapter Ldr
The steering box is the problem? Sucks it screwed up the camping weekend
