Camera on back of 5th wheel
I am thinking about adding a camera to the back of my 30' 5th wheel camper to keep an eye on my boat. Any suggestions on where to mount the camera, what type of camera to purchase, how to wire it, etc. would be greatly appreciated. Pictures of where you mounted the camera would help. Thanks in advance.
What I did on mine for our bumper pull, I already had a 7" touchscreen head unit in the dash. I bough two rear view cameras of the same model, $15 ebay specials, plate mount style. When I wired it in, I split the video connection behind the bumper near the hitch. I mounted the second camera on the rear of the trailer and ran the video wire up the frame and when I hitch up, I just swap the connection over to the trailer wire. Then I can access the camera at any time going down the road.
If you don't have an in dash unit already, you could go with one of the wireless kits.
Well here is a link that might help.
RVS-770613-213 1 camera set up 5th wheel | backup camera system | Rear View Safety
I was leary of drilling holes into my rear cap (that camera is HEAVY), so I put the camera on my ladder. Put some rubber around it to keep it rubbing on the black metal and zip tied the wire on. I then ran the wire under the 5th, encased in plastic wire protector, zip tied it underneath, up through the bottom of the front storage compartment, and added an angle iron for the plug. Works great and on 100% of the time towing (works excellent at night also).
How heavy is the camera? All I see in the specs is the weight of the monitor.
Now, if you have a solid backing to screw into, then go ahead. I wasn't sure where mine would be solid, so it was easy for me just to attach it to the ladder. Plus, I was able to easily remove it before storage.
my996duc1
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
16
09-22-2011 05:51 PM
Happyreefer
03-23-2009 04:20 PM
