Mechanical fuel pump ?
Old May 1, 2014 | 01:17 PM
-mywheels-'s Avatar
-mywheels-
Old May 1, 2014 | 01:25 PM
turbohunter's Avatar
turbohunter
Have you checked tank the vent?
Old May 1, 2014 | 01:37 PM
Filthy Beast's Avatar
Filthy Beast
You shouldn't need an "O" ring on flared end tubing provided they mate up together well. You could try some plumber's tape around the threads of the nut for a better (air tight) seal. That looks like your tank in the picture....so heat would not be an issue with the tape there.
Agree with Turbohunter on checking for gas tank venting/equalized pressure, too.
Old May 1, 2014 | 02:12 PM
-mywheels-'s Avatar
-mywheels-
I pulled the filler cap off and it didn't make any difference. Does this mean tank is venting ok? I have my tank vented thru the carbon canister.
Old May 1, 2014 | 02:43 PM
Filthy Beast
Probably...but I would do a visual check on the lines from your tank to the cannister for being pinched. Check those vacuum lines at the can, too.
OK...let me re-group.....you said you have good flow from the tank to the pump, correct?
And from the pump to the filter to the carb is where the problem lies, yes?
Have you disconnected the feed line from the pump to the carb, at the carb, and tried cranking her? Do you get good flow from the pump?
Have you checked the carb float(s) for correct position?
Forgive me if these questions were already asked/answered...just trying to put things in order......and being a grumpy old fart, I'm a bit slow in memory.
Old May 1, 2014 | 03:59 PM
-mywheels-'s Avatar
-mywheels-
Thanks for all of your help. Umm..I forgot to mention this truck has 2 tanks. Between the two is the switch valve. As an experiment, I directly connected the in-cab tank to the main fuel line. Apparently the valve is bad, because the truck runs smooth now. I apologize profusely for not mentioning this before.
Ps. I'm a young fart who lost my patience prematurely. I got a metal shaving in my eye. The eye doc decided to scrape it out with a long pointed probe. @#$%! I posted this thread right after my appt.
Old May 1, 2014 | 04:44 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
78/79 duel fuel tanks frame switch-Duralast/Universal 3 port fuel selector valve used with SW48 toggle switch Part Number: FSV4
Old May 1, 2014 | 05:25 PM
-mywheels-'s Avatar
-mywheels-
Truck is a early 77. I didn't look to see which valve I have. I'm assuming its aftermarket.
Old May 1, 2014 | 05:38 PM
77&79F250's Avatar
77&79F250
Is it a manual change valve in the floor down by the dvrs seat edge or in the environmental control panel?
I think the floor valve is possibly a dealership installed tank and the actual dash switch one is OEM.
The switch one in the dash, has the valve back by the crossmember, just in front of the aft tank. I believe that is the valve I posted in #23.
Old May 1, 2014 | 07:37 PM
-mywheels-'s Avatar
-mywheels-
It's a PO installed setup. Label on the switch says Travel Tanks. Located on the left side of steering wheel. I'll take the valve with me to the parts store and find something similar.
Old May 2, 2014 | 01:49 PM
Filthy Beast
Thanks for all of your help. Umm..I forgot to mention this truck has 2 tanks. ARRRRRGGH!
No problem on your being peckish after the eye deal. Understandable! Been there myself many years ago. Not a picnic wearing an eye patch with the antibiotic junk oozing out from under the patch, and trying to do stuff.
Glad to see you have a handle on the situation, and moving forward. Good luck.
Old May 17, 2014 | 04:57 AM
hermancm's Avatar
hermancm
I also thought that a mechanical pump just worked or it didn't but after mine failed altogether this winter my truck starts easier and the clear filter does fill where as it would only fill half way with the tired old pump.
2manytickets
Apr 23, 2018 04:43 AM
gprust
May 8, 2017 03:10 AM
Jbert50021
Nov 1, 2015 10:23 PM
Tidife
18
May 20, 2014 09:53 PM
Shultzie
May 2, 2010 02:57 PM
