it just shuts off!!
Old Apr 29, 2014 | 10:39 AM
imjwm's Avatar
imjwm
it just shuts off!!
Hello
Hey I need some idea as to what might be the problem with my 1995 f250 7.3l diesel! A few days ago when I had just started my truck and started driving it just shut off! I turned the key off and then started it again and it started just like normal! Then yesterday I was driving it down the road and it shut off about 2 or 3 times but it would start again without me turning the key or slowing down, it just lurched a little bit? Then today when I tryed to start it one time it turned over for longer then normal? Does anyone have an idea of what it might be?
Thanks
P.S. I will be going on duty soon till Sunday so I prob won't reply till then!
Old Apr 29, 2014 | 11:11 AM
madpogue's Avatar
madpogue
Automatic or manual transmission?
When it restarts on its own, does the WTS light come on?
Old Apr 29, 2014 | 11:13 AM
madMatador78's Avatar
madMatador78
CPS??? I would have a spare on hand anyway, Ford or International Only, parts store ones are junk and can be bad out of the box.
Old Apr 29, 2014 | 01:00 PM
madpogue's Avatar
madpogue
^^^^ CPS is the other prime suspect, and a spare is a good thing. But before crawling under the truck, you'll want to narrow it down. If the WTS light comes on when it re-starts on its own, that indicates an interruption in main power (loose fuse, bad ignition switch, etc). If it doesn't, but the tach drops to zero and then returns, that fingers the CPS / wiring to it.
Old Apr 29, 2014 | 08:04 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
Does anybody know which is the correct CPS IH # part?, I have two of them: 1876736C91 and 1825899C93
Old May 4, 2014 | 01:40 PM
imjwm's Avatar
imjwm
It is an automatic transmission. the time I was moving fast it started on its own but one time when I just started moving it shut of and I had to restart it with the key. Also there are no lights that come on!
Old May 4, 2014 | 08:43 PM
madpogue's Avatar
madpogue
With an automatic, if you're going fast enough, and the interruption is short enough, and esp. if it's just the CPS and the PCM is still active, the torque converter will stay locked, and will keep turning the engine through the drivetrain. So when the engine control is restored, the engine will start running again on its own. But if you're just starting out, when it's interrupted the TQ won't keep the engine turning and it will stall, and that's why you have to turn the key.
The TQ staying locked, plus the WTS light not coming on, indicates the PCM power is NOT being interrupted, so the CPS is def. the prime suspect. That, or the wiring to it.
I've got an IH CPS in the glove box; I'll check that part number.
Old May 5, 2014 | 11:38 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
I called to the IH dealer here in my town and gave me a NEW # PART:
1876735c91, could you verify that in the IH dealer in USA? or if this is the number of your IH CPS?
Old May 5, 2014 | 03:31 PM
Bob Cat's Avatar
Bob Cat
I had the CPS issue a few months a go and the ones I got from the Ford dealer is part # F7TZ-12K073-B. Hope that helps. I've not had any problems since changing mine.
Old May 5, 2014 | 08:10 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Smile
Thank you for the input, but here in Mexico, Ford doesnt sell that sensor, only IH.
Old May 5, 2014 | 08:29 PM
JWC 3's Avatar
JWC 3
I show 1821720c99 for mid 97 and older . .... 1825899c3 for mid 97 and newer .
Old May 5, 2014 | 08:49 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Lightbulb
Wow, more different numbers. BTW I think you miss a 9 in the second number:
1825899c3 vs. 1825899c93
Old May 5, 2014 | 09:05 PM
JWC 3's Avatar
JWC 3
Yes .. I missed the last 9 in my post . Sorry .
Old May 6, 2014 | 10:22 AM
imjwm's Avatar
imjwm
Thanks for your help. I ordered one yesterday and I'm hoping to put it in next Monday. Thanks
Old May 6, 2014 | 05:03 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Exclamation
BUMP, BUMP.
