Heater Core Replacement - confused
Old Apr 29, 2014 | 07:06 AM
04FordRanger's Avatar
04FordRanger
Question Heater Core Replacement - confused
Ok confused - I have an '04 Ford Ranger Edge 4x4 4.0 v6 needs a new heater core -
1. I read that it can be changed by an access panel under the glove box area,
2. but have been told it will take 10 hrs and $900 and have to have the dash taken apart. Sooo, which is it?
Thank you for any help,
Christine
Old Apr 29, 2014 | 08:46 AM
Rockledge's Avatar
Rockledge
What kind of symptoms are you experiencing? Is the heater core leaking? Lack of heat?
I read that it can be changed by an access panel under the glove box area.
I believe that's true with some of the older Rangers, but not for your '04.
Old Apr 29, 2014 | 08:53 AM
04FordRanger
It's blowing out a bunch of dust crap, fogging my windshield up and there is an odor. No leakage yet, put tape over my control so I dont use it and make a bigger problem. I was hoping it wouldnt be a difficult fix. No money to get it done now - glad its spring!
Old Apr 29, 2014 | 09:10 AM
Rockledge's Avatar
Rockledge
If you smell coolant and the windshield is fogging up, then it probably is the heater core like you suspect.
This video will give you an idea as to what the job entails. The instrument panel has to be pulled back, at a minimum.
Old Apr 29, 2014 | 11:18 AM
Josh S's Avatar
Josh S
What an incredible amount of work for a heater core! Any idea why Ford made it so difficult to change on the 'newer' models?
Old Apr 29, 2014 | 02:04 PM
04FordRanger
I'd love to know that too - why go from easy access to ripping your truck apart. That I find depressing knowing my truck has to basically be gutted just to replace that small part. I love my truck but will not be a witness to her bareness for this - I think I may cry lol.
Thanks for the video
Old Apr 29, 2014 | 07:17 PM
exranger06's Avatar
exranger06
That amount of work for a heater core replacement is pretty typical for most vehicles. The older trucks with the easy to change cores were the exception, not the rule.
Old Apr 29, 2014 | 07:37 PM
AFX427MR's Avatar
AFX427MR
The 80's and 90's were just as bad
I worked on many Ford cars back then and the Mustang, Cougar, T-Bird, and Lincolns all had to have the a/c discharged, steering columns dropped,and the dash removed to get the heater box out of the car to split it open to get to the core. My charge back then was $700 plus parts and it would take about 10 hours to get the job done. I hated them because every nut and screw was a different size and by the time you got the thing out you had nearly your whole tool box in the floor of the car.
The kicker was that these were the worst to service but they had failures more common than any other cars. I wondered if the guy that designed this system and spec.ed out the cores got his bonus for the great planning he did.
The Ranger without a/c back then, the core could be changed faster than the amount of time it took to get the heater hoses off.
superrangerman2002
Feb 14, 2015 03:58 PM
WarrenStiehl
Sep 21, 2012 05:03 PM
redneckbrat
Sep 30, 2006 11:25 AM
1988f150pu
Jun 27, 2006 08:21 AM
Red_EB_Bronco
1978 - 1996 Big Bronco
Aug 4, 2003 01:43 AM
