Sponsored by: Real Truck
zf6 damage
Old Apr 28, 2014 | 10:30 PM
tonz3672's Avatar
tonz3672
zf6 damage
hi there,
first of all looking for some advise.
Was pullin passat home 50 miles round trip this saturday and downshifted into 3rd.
As the gear engaged it let out a loud clunk locking into 3rd gear. was able to find neutral after a day but slammed into gear just idiling. can find nuteral on pattern but not actually get there....also drags right rear tire upon disengaging clutch. any advise would be helpful. 1999&half psd zf6 1 ton single
Thanks
Tony
Old Apr 29, 2014 | 06:42 AM
Tom's Avatar
Tom
Hi Tony,
Sounds to me like your clutch has failed. The fact that it "drags" the rear wheels upon disengagement implies to me that the clutch isn't disengaging properly. I believe the clutch in these trucks is hydraulic, so you may have low fluid or a problem with your master or slave cylinder. The clutch itself could also have failed.
Completely different application, but I had the clutch fail on my '07 Kenworth a few years ago. The symptoms were much like you described, and when pushed the clutch in to come to a stop the truck wanted to keep on going. Was hard as hell to get into gear, and I had to shut the engine off to shift to 1st from a stop.
DON'T drive it like this, if you're not up to fixing it yourself it needs a tow to the shop. If the failure is in your clutch you will do internal transmission damage trying to drive it like that!
Old Apr 29, 2014 | 10:23 AM
tonz3672's Avatar
tonz3672
zf6 damage.
Hi there,
Thanks for the input. Ijust put a south bend in it 2000 miles ago and it disengages fine but the gears are all messed up and it is locked in some gear. I can use clutch to start truck but as soon as I engage clutch it will die ...seems to be stuck in 3rd or 5th . And neutral is lost in the pattern? On the stick it seems to be in neutral but no luck. Gonna tear it apart this week and examine the clutch
Old Apr 29, 2014 | 11:05 AM
Tom's Avatar
Tom
How is the oil level?
Old Apr 29, 2014 | 11:14 AM
tonz3672's Avatar
tonz3672
Was good when I did my clutch. Will find out this week. Its my work truck but also my build truck. So im kinda glad it happend now at 400 hp 800tq i have 400 k on tranny and it seemed to fail. Any oil suggestions for when I put a new tranny in?
Old Apr 29, 2014 | 03:24 PM
wizkid00104's Avatar
wizkid00104
I like AMSOIL ATF. Great stuff.
You may have bent or broken a shift fork in the transmission.
Old Apr 29, 2014 | 03:46 PM
tonz3672's Avatar
tonz3672
Thanks wiz kid
Sounds like the culprit.
Ill consider amsoil
Old Apr 29, 2014 | 03:53 PM
wizkid00104
If you do consider AMSOIL, they sell a yearly dealer membership for $20. It gets you about 25% off all products. I bought it the last 2 years and I buy all my fluids and greases from them now and it really pays off. Plus you get the top of line stuff.
I've never rebuilt a ZF6, but I did do an M5OD from a Ranger and manuals are remarkably simple.
I am not sure if this is true in Super Duty, but if you pull the shifter boot off, lift up the carpet or rubber flooring and remove the trans tunnel cover, you might be able to take the top plate off the transmission without actually removing it from the truck to diagnose the problem. I had a ZF6 in an 04, but I never had to do this. Pulling the shifter off will expose the shift rails that the shift forks ride on. There may even be a slim chance that you could repair the transmission without taking it out of the truck. There are a lot of ifs in that though...
Edit: Disregard that, I just looked at a photo and it does not have a top cover to remove. Sorry for the false hope...
Old Apr 29, 2014 | 03:58 PM
je5's Avatar
je5
tonz,
Jasper has the units for 2WD but not 4WD. Use Mercon V or Motorcraft full synthetic ATF manual trans fluid (P/N XT-M5-QS).
ZF6's load from the rear and are complex units to rebuild. Jasper sends them to ZF to rebuild.
Old Apr 29, 2014 | 06:11 PM
Leon82's Avatar
Leon82
Did the shifter feel out of place when it was in gear? I bent a shift fork In a T-5 once and 4th gear was like neutral and third was almost in the radio.
Stymied
21
Jun 13, 2016 09:23 PM
sancochojoe
22
Jul 19, 2006 07:36 AM
john112deere
1983 - 2012 Ranger & B-Series
Oct 20, 2004 01:41 PM
nebi
Apr 13, 2004 08:57 PM
RandysF150
Oct 29, 2002 09:41 PM
