6.9 core support?
Old Apr 26, 2014 | 05:05 PM
williamyoung729's Avatar
williamyoung729
6.9 core support?
i need to replace the core support in my 83 f350 with a 6.9, i havent been able to locate a new one. dose anyone know where to buy one? thanks
Old Apr 26, 2014 | 05:41 PM
ctubutis's Avatar
ctubutis
Look on car-part.com to find junkyards in your area that claim to have one.
Old Apr 26, 2014 | 08:33 PM
Franklin2's Avatar
Franklin2
If can't find one, and you are handy with a welder, you could get a gas one and repair yours. It's a lot of work but sometimes it's your only choice.
Old Apr 27, 2014 | 12:15 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by williamyoung729
I need to replace the core (radiator) support in my 83 F350 with a 6.9. I haven't been able to locate a new one.
Does anyone know where to buy one?
Two possible radiator supports for 1983 F350 6.9L =
E3TZ-16138-F .. Radiator Support-Diesel with Xtra or Super Cooling Radiators / 25 5/8" x 31 1/8" opening radius / Obsolete
1983/86 F250/350 / Last MSRP: $675.15 ~ Dealer net cost: $405.09.
No Ford dealer or obsolete parts vendor has any.
E4TZ-16138-D .. Radiator Support-Diesel with Standard Cooling Radiator / Obsolete
1983/84 F250/350 / No prices available.
CURRENT RIVER FORD in Doniphan MO has ONE = 573-996-7163.
No other Ford dealer, no obsolete parts vendor has any.
Old Apr 27, 2014 | 11:52 AM
williamyoung729
thanks for the replies, i was hoping for a new one, so thanks number dummy ill give them a call if not i will have to get a good used one mine is junk, below rad gone drivers side mount gone,
what is the diffrence between the gas and diesel ones? just a bigger opening for the rad?
Old Apr 27, 2014 | 01:18 PM
fellro86's Avatar
fellro86
On a gas support, the bar under the radiator goes straight across. On a diesel, it dips almost to the bottom of the frame. Now, there are some diesel supports in that year range that were on non-a/c or dealer add-on a/c that were pretty much like a gas support. The trade off is that the radiators can be hard to find. They were very uncommon.
Old Apr 27, 2014 | 04:43 PM
Franklin2's Avatar
Franklin2
It may have not been made clear enough in the previous post. There were two types of radiators for the diesels, a very tall narrow one and a wide one. You need to see which one you have, so you can get the right core support. Most of them I have seen are the very tall units.
Old Apr 27, 2014 | 05:52 PM
NumberDummy
If this isn't clear, what the hell would be?
Specs are listed for one of the supports, it's up to the OP to measure the opening radius.
Old Apr 27, 2014 | 07:22 PM
williamyoung729
it was clear enough there were 2, thank you fellro86 for explaining the diffrences in the two
Old Apr 27, 2014 | 07:33 PM
ctubutis's Avatar
ctubutis
Oh Grumpy One has bellowed.
Old Apr 27, 2014 | 07:57 PM
NumberDummy
"She, who must be obeyed" left for Omaha earlier today. When the cat is away, the grumpy mouse shall play!
Old Apr 27, 2014 | 11:21 PM
bruno2's Avatar
bruno2
William, in numberdummy's first post he had the dimensions of the opening in the center of the core support. If it matches those dimensions it's the first one he listed, if not it's the second one.
Old Apr 28, 2014 | 08:14 AM
Gary Lewis's Avatar
Gary Lewis
And I was going to send him a PM today, but now I'm shaking in my boots thinking about the response I might get.
Old Apr 28, 2014 | 09:56 AM
ctubutis's Avatar
ctubutis
He shut off his PM capability, hafta use e-mail or telephone.
big ole ford
Aug 16, 2018 07:42 PM
g2cn
Apr 25, 2016 08:10 AM
kyle j
36
May 21, 2015 06:01 PM
cobraguy
Nov 17, 2009 08:47 AM
cykoticford
Mar 7, 2008 03:00 PM
