Tranny? Rear end?
Old 05-05-2014, 08:50 PM
twfish's Avatar
twfish
twfish is offline
Originally Posted by 85e150six4mtod
Someone correct me on the CEL/code thing. Just because there is no CEL does not mean there are not codes stored--is that correct?
TPS, MAF, anything in that area that's talking to the engine computer is a suspect. Even a temperature sensor that's telling it the engine is cold will cause a rich mixture and lead to poor fuel economy.
Correct to a point on the codes.
Mileage yes theres always alot of factors, however the other problems would indicate something more along actual functioning parts. Do not beleive a tps or temp woukd cause it
Old 05-06-2014, 07:15 PM
P.Bronner's Avatar
P.Bronner
P.Bronner is offline
Throw a fuel filter at it. I know this sounds almost absurd but I've seen these basic symptoms in fuel injected vehicles caused by fuel starvation. It certainly could be a tps sensor but I've never seen a faulty tps NOT produce a CEL. As far as sensors go, my first suspect would be MAP. I have seen those produce values out of range with no CEL. I'd still throw a fuel filter at it first.
Old 05-07-2014, 03:48 AM
ProgDrummer79's Avatar
ProgDrummer79
ProgDrummer79 is offline
Cleaned the MAF sensor. Doesn't seem like it did much, if anything.
I will try fuel filter next. Could the MAF sensor just be bad and need changed? normally I would think if it were actually bad, it would show a CEL?
Old 05-08-2014, 10:07 PM
mattsautobody442's Avatar
mattsautobody442
mattsautobody442 is offline
My 04 truck does the same thing, there's an issue with the forward clutch packs in the transmission. i change my tranny fluid so often its a minor issue but it still happens occasionally on a slow down and punch it move. trans shop said if i baby it i probably won't have a serious issue. its done it since i bought it at 66k and its got 192k on it now and i plow and tow with the best of them and its never changed. my buddy has an 08 like mine and his did it and it was plugs and coils. i would do plugs, msd coils and a trans service and take it from there...
Old 05-08-2014, 10:42 PM
85e150's Avatar
85e150
85e150 is offline
Received 1,611 Likes on 1,313 Posts
You don't need a CEL for there to be a code. Anyone try to read codes on this?
Old 05-09-2014, 06:59 PM
mericanwit's Avatar
mericanwit
mericanwit is offline
02 Sensor, vacuum leak, fuel injector acting up, too many issues with these 04 5.4l motors... I had a running lean code, spray cleaned MAF sensor and changed 02 sensor although alot better still has the shudders going uphill, oh well...
Mr.Jackson
2009 - 2014 F150
78
01-09-2017 11:23 PM
osb
Modular V8 (4.6L, 5.4L)
09-09-2012 03:28 PM
Old93f150
09-17-2010 08:43 PM
bigbluebronco43
Ford vs The Competition
28
10-12-2005 08:59 PM
sinister73
52
03-11-2004 11:27 PM
Quick Reply: Tranny? Rear end?
