5.4 performance/responsiveness question
Old Sep 1, 2012 | 01:59 PM
osb's Avatar
osb
Looking for some insight...I'm coming from the Ford diesel world, so I'm not too familiar with the 5.4 motor.
Recently purchased a 2010 F150 for my son to drive. It's an Fx4 Supercrew, with the 5.4 motor. (has 90K miles)
truck is in great shape, it's been checked out thoroughly by my mechanic, and seems to run fine. However, it occasionally exhibits what i'd call a lack of responsiveness. coming out of a turn, or attempting a pass, it's almost like it's ignoring throttle input. you have to really poke it to get it to downshift. Other times it seems to be fine. It has power, but feels like the transmission, or the ECM is fighting me when i want it to get up an go.
Is this normal behavior for the 5.4?
if so, would a basic tuner (superschips / SCT, etc) wake it up a bit and make it more responsive?
Is there some other common issue with these motors/tranny's that might be going on?
The only mechanical issue it's had was a brief Check engine light. we pulled the codes and it was for the O2 sensor. It went away, and the mechanic said we can wait and address it when/if it returns, and it shouldn't be affecting performance.
thoughts?
Old Sep 8, 2012 | 02:09 PM
enriched&beyound's Avatar
enriched&beyound
thoughts?
extremely spoiled/luck kid...just sayin not hate'n
I would address the O2...it maybe just a bit lazy in reponding ...which plays back to the Air to Fuel ratio....which end result is maybe lazy throttle reponse. It maybe that the tranny is sticking in a higher gear, not down shifting as well as it should...leaving it "feeling" boggy
yes a tunner will "wake" this up...I would go towards the better/higher end that can handle "future" affects/additions....bigger rims and tires, exhaust , shift points etc.
if your concerned about durabilty...then re-gear to 373 gears or 410 and response will improve very effectively
Old Sep 9, 2012 | 03:28 PM
honestcharlie56's Avatar
honestcharlie56
mine is the same way, I really wouldn't worry about it. If you do want to get rid of it a tuner will get ya there.
SuperDutyScaler
Apr 23, 2014 06:15 PM
slam1991
1997 - 2003 F150
Mar 13, 2014 11:10 PM
Whippled04
Nov 9, 2007 10:35 AM
Sagegrouse
Mar 3, 2006 05:22 PM
JRFX4
2004 - 2008 F150
Jun 1, 2005 08:47 PM
