Easy Project Gone Very Wrong
Old Apr 26, 2014 | 08:00 PM
fmc400's Avatar
fmc400
MSEE
Originally Posted by phboyer
I have continuity on both of the posts and nuts on the back of gas gauge when I ground the other side. Doesn't that mean I am getting power to the gauge?
I'm having a little trouble following what you're saying. Continuity is something between two conductors; if you're trying to vet the continuity of the gauge winding itself, you'd actually want to measure the resistance. Continuity is a yes/no test.
The plastic that surrounds one of the posts broke when I took it off when changing out the instrument cover back. It was working fine before that.
Breaking the plastic brace is a common mistake when removing the two small nuts on the back of the gauge. The posts are not strong enough to stay put while the nut is unscrewed - the correct procedure is to hold the posts steady with a pair of pliers while gently working the nut loose. Soldered to each post on the inside of the gauge is a very thin gauge piece of mag wire - you don't want the posts spinning too much.
Regardless of what happened and what the gauge is or is not doing, carry out the test described in Mike's post. This is a very common troubleshooting technique that will pinpoint where the problem is. That's why I suggested searching, as that procedure gets pulled up almost daily. Mike was kind enough to put it here too. This will tell you if the problem is toward the gauge or toward the sending unit. Since you reported that the issue didn't occur until you changed the cluster, I imagine you will find the needle does NOT peg full when carrying out the test procedure. If that's the case, there are a handful of possible causes, and we'll go from there.
Old May 17, 2014 | 06:16 AM
hermancm's Avatar
hermancm
1975/79 F100/350 - 1975/80 Econoline - 1978/79 Bronco.
The factory installed instrument cluster backs were made of a composition material that can TURN TO DUST before your very eyes!
1981: FoMoCo came out with hard plastic cluster backs for Econolines that were also the service part replacements for these POS composition cluster backs.
E1PZ-10848-A .. Hard Plastic Cluster Back-Use with Oil & Amp Gauges / Obsolete
1975/79 F100/350 - 1975/91 Econoline - 1978/79 Bronco.
E1PZ-10848-B .. Hard Plastic Cluster Back-Use with Oil & Amp Warning Lamps / Obsolete
1975/79 F100/350 - 1975/86 Econoline - 1978/79 Bronco.
Several years ago, Carpenter bought all of FoMoCo's remaining inventory of these cluster backs. So they're NOS, not repro's.
Hey there NumberDummy, glad to see your still here! Thats exactly what you told me about my failing instrument shell last year and you were spot on! bit I haven't bouGhT one yet as mine id still hangin together but I'll have to do it eventually.
Old May 17, 2014 | 08:57 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
I don't really care about the oil pressure
You will when your motor blows up and you had no warning, cause you "don't really care about oil pressure".
Oil pressure and eng temp are the two most important gauges to have IMO.
Sound like a cluster backing issue and the boys have you line out on troubleshooting, so stick with it. But get the oil pressure gauge working also.
It could be a sending unit or a wiring/gauge problem since you are working in that area, I'd bet.
Aftermarket oil press and temp gauges are easy to install and more reliable anyway.
kincfu
15
May 3, 2016 06:12 AM
MyName1sMud
39
May 11, 2012 09:41 PM
digitalrancher
Apr 1, 2007 10:14 PM
RR4E
Jan 7, 2005 04:45 PM
deano7xi
Feb 11, 2003 02:15 AM
