connected the battery backwards
Old Feb 10, 2003 | 02:19 AM
deano7xi's Avatar
deano7xi
Unhappy connected the battery backwards
I connected the battery backwards in my 81 f-150 now nohting works. Is there a main fuze i could of blown or mabye the fusible links.
What do i do!
Old Feb 10, 2003 | 03:06 AM
nordo's Avatar
nordo
Deano,
When you say nothing works ,do you mean no lights, no crank?
If so grab a test light and start with the obvious, the battery, check for volts. Then work your way down the smaller of the wires from the positive to the fusible links, to the solenoid and in to the harness. If you are not getting crank, sounds like you got an open circut between the solenoid and the battery. If you got no dash lights as well, I rekon the fusible link has blown and you will need to replace.
See how you go
Nordo
Old Feb 10, 2003 | 09:49 AM
cdd5599's Avatar
cdd5599
You blew your fuseable link. It is located on the wires coming off of your starter solinoid,run down your inner fender and head twards your alternator. You may have to undo some of the balck tape to get to it. I did the same thing. You can replace it with a wire for a patch . But it is better to go to the junkyard and splice in a new one.
good luck,
Chuck
Old Feb 11, 2003 | 02:15 AM
deano7xi's Avatar
deano7xi
Hey thaks alot
i changed the wrong fusible link. I feel like a dummy for hooking the battery up backwards oh well its all good now.
ajacobson
Mar 7, 2014 02:45 PM
tdives
1997 - 2003 F150
Jan 25, 2012 04:29 PM
rsalter66
29
Mar 24, 2008 06:55 AM
Bronco2Nic
Jan 10, 2004 07:55 PM
mooktank
27
Sep 23, 2002 11:39 AM
