Eec-v Codes
Old Jul 5, 2003 | 10:33 AM
medman's Avatar
medman
Question Eec-v Codes
I HAVE A 97 RANGER 2.3L, THE HAYNES MANUAL SAYS I CANNOT CHECK THE CODES UNLESS I HAVE A SCAN TOOL. IS THERE ANYWAY AROUND THAT? ALSO WHAT IS THE EASIEST WAY TO CHECK THE O2 SENSORS? MY TRUCK HAS 105K ON IT. IT HAS NO POWER STARTING OUT, BUT ONCE IT GETS GOING ITS FINE.
Old Jul 5, 2003 | 12:57 PM
Rockledge's Avatar
Rockledge
Eec-v Codes
Hi medman,
WHY ARE YOU YELLING? TAKE OFF THE CAPS BUTTON. We can hear you just fine.
There is no way around it....you must use a scan tool to retrieve the codes. Many auto parts places like Autozone will pull the codes for free.
Also, read here: Oxygen Sensor Info & Testing
Old Jul 5, 2003 | 01:42 PM
medman's Avatar
medman
Eec-v Codes
auto zone wont help you if the check engine light isnt on. they told me you cant check codes if its not on, i just laughed at them. i guess ill have to go to ford, god help me. they get 60 bucks an hour. Or i can just replace them and hope it helps.
Old Jul 6, 2003 | 08:47 AM
oppy's Avatar
oppy
Eec-v Codes
You could buy a code reader for around 100 bucks.
Old Jul 6, 2003 | 02:54 PM
medman's Avatar
medman
Eec-v Codes
i disconnected the ground off the battery, waited about 10 minutes then hooked it back up. my check engine light came on, so i took it to auto zone. i had 3 codes, 135-bank 1, 141-bank 1, and 171-too lean. now i just have to figure out where to go from here. any suggestions?
Old Jul 6, 2003 | 10:01 PM
Rockledge's Avatar
Rockledge
Eec-v Codes
Because your Ranger is OBD-II compliant, your codes are probably as follows:
P0135 and P0141 (Heated Oxygen Sensor Circuit Malfunctions)
P0171 (Lean System Condition)
You can find a list of diagnostic trouble codes and their possible causes here.
Sounds as if your Bank 1 Upstream and Downstream Heated 02 Sensors are trying to tell you something ....probably directly related to the Lean System condition.
