Removing ps pump
Old Apr 25, 2014 | 03:08 PM
fordka's Avatar
fordka
Removing ps pump
My pump just started violently shaking and smoking and i took the belt off and i cant even turn it by hand. Its also dripping out the shaft. How do you get those metal pulleys off without bending them so i can take the 3 bolts out with removing the whole friggen bracket assembly.
Old Apr 25, 2014 | 03:09 PM
fabmandelux's Avatar
fabmandelux
It takes a special puller to remove it...
Old Apr 25, 2014 | 03:12 PM
RIKIL's Avatar
RIKIL
What year, make and model?
If it's the same as my '92, you'll need to get a pulley puller thinga-ma-bob. Like this - Performance Tool Power Steering Pump/Alternator Pulley Puller, Model# W87020 | Specialty Tools| Northern Tool + Equipment
They can be purchased at just about any auto parts store. The pulley is pressed on so it will take some effort to get it off.
Also make sure you have the tools to put it back on. Like this - Performance Tool Ford Power Steering Pump Pulley Installer, Model# W87021 | Specialty Tools| Northern Tool + Equipment
Old Apr 25, 2014 | 03:28 PM
fordka's Avatar
fordka
95 f150 4.9. Will these tools work the same on the plastic ps pulleys too. I have a pump off and old truck and it has the plastic pulley.
Old Apr 25, 2014 | 03:29 PM
RIKIL's Avatar
RIKIL
I can't specifically answer about your 4.9 as it may be a little different than my 5.8 but I use them on my plastic pulley without issues. I don't recall ever having a metal pulley on mine - if I did it was a LONG time ago.
Old Apr 25, 2014 | 03:32 PM
fordka's Avatar
fordka
Ya mine has a steel one on it. Older ones had a plastic one
Old Apr 25, 2014 | 03:45 PM
dixie460's Avatar
dixie460
I have this:
Pulley Remover and Installer Set
Works fine on either steel or plastic pulleys, is the exact same thing that the auto parts stores have, and it's only $20 at HFT!
Old Apr 25, 2014 | 03:46 PM
RIKIL's Avatar
RIKIL
Originally Posted by dixie460
I have this:
Show off
Of course, since it's from HFT it probably has lead and thallium in it.
Old Apr 25, 2014 | 03:57 PM
SAF's Avatar
SAF
do you have an autozone near you? They will loan you the puller/installer...no charge. Pay for it (deposit) use it then return it and they issue a full credit
Old Apr 25, 2014 | 04:15 PM
fordka's Avatar
fordka
Not really close but i have someone in the city that can get one i might get the HF one so ill always have one or just buy one from the auto store
Old Apr 25, 2014 | 06:19 PM
dixie460's Avatar
dixie460
Originally Posted by RIKIL
Show off
Hahaha... yeah probably does but for the price it can't be beat. It's actually a nice, solid tool kit.
I noticed the quality of their stuff has been improving over the years. Still some cheap junk to be found of course, but also a lot of decent tools and equipment for a decent price these days.
Old Apr 25, 2014 | 09:11 PM
fordka's Avatar
fordka
When i take this pulley off is the whole bracket and nonsense gonna have to come off. I got a puller similar above but its not right. Its completely threaded all the way and doesnt have the round piece on the end to fit in the whole
Old Apr 25, 2014 | 09:18 PM
RIKIL's Avatar
RIKIL
Remove the pulley, remove the 3 bolts and the pump should come out the back. Then just need to remove hoses. This is how it is on my 351w
Old Apr 26, 2014 | 04:52 PM
fordka's Avatar
fordka
Ok now that i got the right puller how do i keep the pulley from spinning. While trying to pull it
Old Apr 26, 2014 | 06:19 PM
RIKIL's Avatar
RIKIL
Put the belt back on
